1963 custom grill
Old Nov 6, 2003 | 07:12 PM
jj292's Avatar
jj292
1963 custom grill
I want a custom grill for my '63 f100 but since no one offers aftermarket ones for these trucks and it is a little more difficult to fabricate (the headlighs are integeral) I was wondering if any one could tell me how to properly make one? I want to have several horazontal bars across it and retain the stock turn signals, I also want to paint not crome it if that makes a diiference.
Thanx JJ
Old Nov 7, 2003 | 12:03 PM
trinogt's Avatar
trinogt
Once you remove the grille, see where you can weld in some vertical support bars. I would use 1/2 or 3/4 mild steel square tubing. Decide how 'flush' you want the grille to be in the front, and weld in the verticals 3/4 back (if using 3/4 steel) from that point, then weld in the horizontals to there, spacing them as you desire. The better thing to do would be to just bolt the vertical supports in (make some kind of flange), and weld the horizontal bars to it, so it can all be removed. You can chrome the whole thing after as well, using this technique. Maybe you can leave the parts to house the headlights? I am not too familiar with the 60's trucks, so I don't know how it all goes together. Obviously, you are going custom, so just think about what it should look like in the end, and what functions need to remain (i.e. holding headlights in)
Mark in Calgary
01ssreda4
General Automotive Discussion
Nov 30, 2015 11:29 AM
Blapensee
6.7L Power Stroke Diesel
15
Mar 30, 2015 09:04 AM
jjpeach
17
Feb 22, 2015 10:35 PM
Mantrin185
Jun 30, 2011 05:18 PM
JJAC
Nov 26, 2002 08:40 PM
