Coolant passing through the throttle body...
Originally Posted by quicklook2
what does make sense? buying a hundai?
part of the reason is for feezing up, part is for emissions.
the government frowns upon bringing the engine to 1500 until warm.
the ozone is not too happy either.
if it really bothers you disconnect it.
Many things make sence and no, buying a Hundai is not one of them.
The coolant passing through the TB does not bother me, but thanks for your concern.
Originally Posted by subford
From the 1992 Ford Shop Manual in the 4.9L section.
Engine coolant is diverted through the throttle body mounting pad to improve cold weather operation.
I had the engine out of my truck, the TB and plenum was off the block and I didn't notice any coolant lines/passages, I sure don't have any coolant lines visible on my 4.9L, I specifcally remember my 302 had a line in and out of the sides of the TB.
I looked under the hood today and did notice that there is a threaded hole with a threaded plug installed..it is on top of the TB right next to the air valve. Signed, confused
Originally Posted by eco
What does a hot/warm throttle body once operating temp is met do for emissions?
the arrow on the instrument that tells my which side the gas fill is on makes no sense to me.
even if it does not bother you, you can disconnect it if you want too.
on
Originally Posted by phoneman91
and Chevy may not be above "bandaid" engineering.
Originally Posted by 924x2150
Subford, come on back, //does this mean there is coolant coming thru a passageway in the block thru to a passage way in the TB?
Mudsport96
26
01-24-2022 07:08 PM
Zacbkennedy
02-20-2017 11:31 AM
tabijan
01-25-2014 11:13 AM
topfile
13
07-23-2012 08:30 PM
