Pcv Valve
Old Mar 31, 2007 | 10:31 PM
90Ford250's Avatar
90Ford250
Pcv Valve
What Effects Would A Dirty Or Blocked Pcv Valve Have On The Truck.
I Have Hesitation The First Second Or 2 Of Exceleration Then Smooth.
Ive Changed The Fuel Filter , Air Filter, Pcv Breather Filter, Plugs Are New, O2 Sensor New, Wires, Distributer.
Also Cleaned The Throttle Body. Could It Be My Pcv Valve. I Also Think It Might Be My Tps.
I Dont Have A Volt Metter That Why I Havent Tested The Tps.
Thanks For The Help.
Old Mar 31, 2007 | 10:38 PM
christcorp's Avatar
christcorp
So many vehicles are unique in how they respond. They have so many interelated parts. A PCV valve however is one of the cheapest and easiest parts to put into the car. It either pops right into the hole, or it's a screw in modem. The average price for one is less than $10. I suggest that you just replace it and find out. If it doesn't change the symptoms, no big loss. It probably needed a change anyway.
Hesitation can be so wide spread. it can be timing, weak fuel pump, sock/filter in the gas tank, spark plugs, rotor, cap, wires, (Matter of fact, the last time I had a hesitation problem with my focus I changed everything. Still a problem. I said screw it and replaced the plug wires. Perfect ever since).
Can you slowly rev the engine and hear the hesitation? Can you get it to hold at that hesitation? If you can, then you can experiment. Good luck. Later... Mike....
Old Mar 31, 2007 | 10:46 PM
90Ford250's Avatar
90Ford250
I Plan On Replacing The Pcv Valve Tommorrow Its Only Like $5. Just Hoped After Fixing Everything ,i Already Have This Would Be The Key To The Hesitation.
Maybe This Will Help' The Hesitaion Goes Away A Little When The Truck Has Been Running For About 5 10 Mins. When You Hit The Gas The Truck Kinda Jumbles Over It Self And Then Catches It Self And Then Smothes Out.
Old Mar 31, 2007 | 11:59 PM
924x2150's Avatar
924x2150
I am not optimistic that changing the valve will improve things. It allows the engine to re-capture gases that used(pre-1973)
to be vented to the outside. It is really just a minor emissions-systems related device. A clogged valve does more harm to the engine seals and gasket if the gases become trapped in the crankcase. If it is blocked, a small quantity of crankcase gas will be blocked from re-entering the throttle body, and shouldn't throw off the computer or shifts.
There are a few other simple things that may be causing your trouble. First take a good look at your vacuum lines, check for broken lines, rotted?missing/brken rubber fittings. there are also two vacuum reservoirs under the hood that need inspection..especially the metal "coffee-can" reservoir mounted on the passenger front wheel well. It rusts out, and bleeds off your vacuum continuosly.
second,... check your IAC, it usually sits on top of the throttle body inlet, I'm not sure what engine you have, my 4.9L IAC is right on top where the air hose meets the TB, the IAC can be cleaned out, it gets full of crud and causes rough performance.
3rd ...pull your diagnostic codes.
Old Apr 1, 2007 | 01:13 AM
Bruce R Leech's Avatar
Bruce R Leech
let us know what hapens
Old Apr 1, 2007 | 11:42 PM
90Ford250's Avatar
90Ford250
thanks for the info. ill check all of that tommorrow. ill keep you posted.
tim_cleav
1983 - 2012 Ranger & B-Series
Sep 12, 2013 02:59 AM
dirtmister16
Nov 19, 2011 07:25 PM
coach123p
New Member Introductions
Jan 18, 2007 11:57 AM
Jakeman711
Aug 29, 2006 04:48 PM
Webslinger
Oct 3, 2005 01:03 PM
