somethings outa whack here..
Note the relationship of the bed to the cab. I measured the bed height on the bottom edge (i removed my boards and strips today) and the height of the frame rails. Everything appears true and "level" I looked at the rear cab mounts, and they appear fine, altho I'm thinking looks may be decieving. Sorry about pic quality, it was taken in BRIGHT sunlight.
Out of wack
suggestion, find a flat surface, check surface with level, maybe garage. Ruler and level, check everything side to side, left side to right side. Something is bent ,warped, mount or bushing missing. First frame to concrete, next bed to frame. Body last because it had to match front clip and you woul have known if that was not right. Have a great day, chuck
I feel your pain. My 56 did the same thing. Here's a pic from my gallery that shows it: (opposite lean from yours): https://www.ford-trucks.com/user_gal...=72200&width=0
It had always been that way since I bought it. I also thought it was the bed. It wasn't. The pic was right after I had just finished extensive mods on the bed (which should have stiffened it) and I knew it was square, as were my frame and bed supports. Checked and rechecked. I had hoped that the work I did would solve the "lean".
Since it wasn't the bed, frame or suppoerts, I figured that the cab had swung over on it's rear mounts (the wishbones). I just crawled under it and used a pry bar between the frame and cab to tweak the low side of the cab up. (I used a scrap piece of steel to spread the load out on the cab). It settled in fine. Everything looks square now. When I get it back together, I'll see if it needs tweaking again.
Have fun.
Have fun.
Thanx for the reples, fellas. Colonel, it may be tweaked, but i don't think so. 49Ford, I did all that, mostly. I'l take more measures manana. Randy, that's a good idea. I'll get under with a pry bar tommorrow. Wayne, when I fantasize about mid fifties Ford F-100's; I got to your gallery to do it. Sorry. I may have to splurge for a set of those adjusters. Those bed side strips you've got on there- are they Mid Fifty flange strips, w/o the angle? Bobby- lopsided? only after too many chilled refreshing beverages. Keep those thoughts coming Guys.
BTW, taking lots of fotos for a new "bedwork" gallery.
I don't know what happened to my photo that was on here, but.. I crawled under there today and was poking around and noticed that the rubber bushing in the rear cab mount wishbones appears to be damaged and are being "squoze" out of their holes. I can't tell if the bushing holes are now "egg shaped". I am torn between buying one or two of the MF adjustable links, or just the bushing sets for both sides, hoping that would be my problem. Question: how hard are these wishbones to remove, and what if anything else has to come off to facilitate this repair? How do you remove the inspection plug? Does it pry out? Thanx
