Sponsored by: Real Truck
rear differential leaking
Old Mar 31, 2007 | 03:01 PM
Greenlawnracing's Avatar
Greenlawnracing
There is a little bit of oil coming out of my rear differential.
My understanding is to simply unbolt the cover, drain the oil, make a new seal with RTV, bolt it back up, and replace the oil.
Is that correct?
Old Mar 31, 2007 | 03:36 PM
mackman's Avatar
mackman
Yup that is it of course you should check cover for flatness at sealing flange then clean off all oil residue RTV not like oil.Brake cleaner is good
Old Mar 31, 2007 | 03:42 PM
Green_Dually's Avatar
Green_Dually
I used the "right stuff" to reseal my meatball...Worked great,apply let set for about 30 mins,then install cover.
No leaks.
Old Mar 31, 2007 | 06:08 PM
Greenlawnracing
Do I need to add a friction modifier?
Old Mar 31, 2007 | 06:12 PM
Green_Dually
That depends on if you have the limited slip rear...
Old Mar 31, 2007 | 06:13 PM
Greenlawnracing
How do I know if I do?
Old Mar 31, 2007 | 06:15 PM
Green_Dually
what model,year,style truck do you have?
what rear do you have 4.10,3.73 ????
Greenlawnracing
2001 F250 diesel super cab 2wd.
No idea what rear end.
Old Mar 31, 2007 | 06:20 PM
99f350sd's Avatar
99f350sd
Tag on the diff. Give us the numbers...Use The right stuff but put the cover on right after you squeeze it out. Stuff comes in a cheese wiz can..Don't put on crackers.
Use synthetic 75-140. Tag has LS or L on it for Limited slip rears..other silicones are crap compared to the right stuff...
Dick
Old Mar 31, 2007 | 06:21 PM
Green_Dually
Look on the drivers door jam,there is a sticker there.It has your GVW on it,also has other info on the sticker.We need to know the axle code to tell you what axle you have.
Old Mar 31, 2007 | 06:37 PM
Green_Dually
you can use this to decode the sticker..
https://www.ford-trucks.com/article/...r_Decoder.html
Old Mar 31, 2007 | 06:57 PM
Greenlawnracing
The tag is really hard to read. I think it says:
s 409 h
3l73 10 5 1b20
Old Mar 31, 2007 | 06:59 PM
Greenlawnracing
the axel is a C1
Old Mar 31, 2007 | 07:33 PM
99f350sd's Avatar
99f350sd
373 limited slip
Old Mar 31, 2007 | 07:44 PM
Greenlawnracing
ok......additive it is? I bought Mobile 1 synthetic gear oil and Trans-x limited slip gear oil additive
http://www.crcindustries.com/auto/co...?PN=402508&S=N
Will that work?
