DIY's machining?
Old Mar 30, 2007 | 07:11 PM
mklemin's Avatar
mklemin
DIY's machining?
Can anybody tell me what is involved in machining the intensifier pistons in the DIY injector stage 2 kit? How hard is it?
Thanks just trying to get as much info to make my descision on what to get
Old Mar 30, 2007 | 09:17 PM
tjbeggs's Avatar
tjbeggs
far as I know you need to take it to a machince shop with the instructions. it will tell you exactly what need to be done. or you can buy the premachined ones and just return your pistons. Sorry I can't be specific cause I have never seen the set up first hand
Old Mar 31, 2007 | 12:21 AM
79f-250custom's Avatar
79f-250custom
are the diy ones you buy flow jet tested i think there called? if they are thats the way i would go.
Mitch
Old Mar 31, 2007 | 08:23 AM
73strokin's Avatar
73strokin
I was also wondering what is involved in machining the intensifier pistons. I am a machinist on the side and would most likely just turn my own pistons.
Old Mar 31, 2007 | 08:38 AM
tjbeggs's Avatar
tjbeggs
Mitch
no the DIY injectors aren't flow benched. you could build the injectors then bring them to an injector shop and have them flow tested. the shop could probably calibrate them too but it will cost you some hard earned green. lots of these injector out there that have been build but not flow checked. including beans early injectors before they got the bench set up.
Old Apr 1, 2007 | 07:08 PM
mklemin's Avatar
mklemin
does anybody have the instructions on the machining? And if i am going to spend the money should i go with stage 2's or just stick with the 1's?
Thanks guys
Old Apr 1, 2007 | 07:30 PM
blue96psd's Avatar
blue96psd
go with the 2s better in my opinion, i have beans stage ones i wish i got his 2s
Old Apr 1, 2007 | 07:41 PM
mklemin's Avatar
mklemin
if i get the twos is there anything else you have to do besides the norm like exaust, intake, and clutch???
Old Apr 1, 2007 | 09:48 PM
fishmanndotcom's Avatar
fishmanndotcom
bigger oil!
-cutts-
Old Apr 2, 2007 | 02:43 PM
mklemin's Avatar
mklemin
to get more pressure do you have to go with the two pump wet up or ios there any other way?
Old Apr 2, 2007 | 04:01 PM
tjbeggs's Avatar
tjbeggs
2 pumps is about the only way except there are a few new high output single pumps(stock style) coming out that may work out. There has already been one single pump setup that used a gear pump but it suffered from hot restart problems. its only marketed for race apps now.
Old Apr 2, 2007 | 05:16 PM
mklemin's Avatar
mklemin
do you have to have the two pumps or is it just better? could you get by with one till later when you could afford it? Also what is "17 degree HPOP "
Old Apr 2, 2007 | 07:25 PM
tjbeggs's Avatar
tjbeggs
you can get away with it no problem but you will set a check engine light when laying into the throttle. it won't hurt anything you just won't be getting the most of your 2's. there are quite a few guys running 2's with big oil. The 17 degree pump is a stock superduty (late 99 and up) is flows more oil and therefore is a good upgrade over out stock pump. if you go to big oil you can use both a 15 and a 17 mated together no problem. so if you come across a 17 get it then keep your 15 around for later.
But since you have a 95 its a little more complicated. you need to modify the high pressure oil pump reservior. here is a write up about it. http://www.nigh.org/HPOP_Mod/HPOP_reservoir_HowTo.htm
Old Apr 2, 2007 | 09:19 PM
ech0sh4y's Avatar
ech0sh4y
What about a 96, is that the same idea with the upgrade?
Old Apr 2, 2007 | 10:12 PM
mklemin's Avatar
mklemin
hey ech0sh4y how much power did your 10K mod give you was it verry noticable or what? I guess i should say is it worth the time? Also is it ok to have the 10 k and shimmed fpr with stage 2's with a chip?
