Cleaning throttle body
Old Mar 30, 2007 | 01:47 PM
tweaked250r's Avatar
tweaked250r
My truck is a 92 f140 with a 4.9 300. I want to clean the throttle body so it runs better however, I once took a one off a 5.8 and it had a tag on it that said "Do not clean with cemicals". I think because of the special plating it had on the inside? Anyways would it be ok to clean mine on the 4.9 with chemicals? Or is it not a good idea? Thanks.
Old Mar 30, 2007 | 01:56 PM
bassproguy07's Avatar
bassproguy07
shouldnt have a problem with chemicals like carb cleaner or brake cleaner. dont use anything like wd40 on it though. clean it with carb cleaner, but let it dry for a bit before starting your engine.
Old Mar 30, 2007 | 02:09 PM
Talyn's Avatar
Talyn
Your not supposto clean them period.
I'm trying to find out what they coat the inside with still.
Old Mar 30, 2007 | 02:12 PM
bassproguy07
why wouldnt you clean them?seems rediculous not to be able to clean a throttle body my budy cleans his on his chevy all the time
Old Mar 30, 2007 | 02:23 PM
Conanski's Avatar
Conanski
I have cleaned mine with carb cleaner many times.. never had a problem. There's no way to fix the idle bypass mechanism without loads of carb cleaner.
Old Mar 30, 2007 | 03:21 PM
andym's Avatar
andym
They receive a special coating at the factory that prevents carbon build-up.
Works great, doesn't it?
Just clean it if it needs it and ignore the warning.
Old Mar 30, 2007 | 03:39 PM
jas88's Avatar
jas88
You don't want to use Brake Cleaner or Berryman's B-12 because they contain Acetone. That will strip off the coating for sure. You can do it, I have, and no catastrophy will result, you just have to clean it more often in the future. What you should use is "throttle body cleaner" and an old toothbrush. Valvoline's works particularly well for me.
WD40 isn't going to do it any harm IMO, it only contains kerosene, and not very much of it, but it probably isn't going to clean it very well, either.
Old Mar 30, 2007 | 05:29 PM
quicklook2's Avatar
quicklook2
sea foam comes in a spray and is a good choice also.
Old Mar 30, 2007 | 08:58 PM
Talyn's Avatar
Talyn
Mine idles funny now i cleaned mine. so...
Old Mar 31, 2007 | 06:39 PM
NeXtras's Avatar
NeXtras
they tell you not to lubricate and/or clean them cause they can get stuck in the open or cloded position. im not sure what exactly the coating is in the TB but i bet its to keep carbon from sticking where they dont want it... like in the mechanisms...
Old Mar 31, 2007 | 08:16 PM
eco's Avatar
eco
Does the 302 have the coating??
I had mine off and I did not see any warning. I did however clean it with a carb cleaner and a pressure washer w/ hot water and soap.
buckfever007
19
Sep 26, 2024 06:57 AM
lanier1974
May 11, 2018 01:23 PM
Budman1962
2009 - 2014 F150
Jun 20, 2016 09:23 AM
pdqtimetrialer
Aug 27, 2012 07:17 AM
boss460
50
Jun 24, 2005 05:06 PM
