4 wheel drive question
Old Mar 30, 2007 | 12:18 AM
zstyle01's Avatar
zstyle01
so every once in a while i'll switch into 4wd and into 4 low to make sure it works. my question is while in 4 high i can turn the wheel only 1.5 turns (i know you can't turn real good in 4wd) is this normal? after 1.5 turns it starts to bind and grind. seems like i should be able to turn more but i'm not used to f250 4x4's.
Old Mar 30, 2007 | 12:23 AM
KelVarnson's Avatar
KelVarnson
No, not on dry pavement. The distance traveled by the front wheels in a turn is not the same as the distance traveled by the rear, and there is no differential in the transfer case to allow for the different speeds.
Old Mar 30, 2007 | 01:38 AM
bkcowboss's Avatar
bkcowboss
Im with KelVarnson, in fact when checking drive trains I will put it in 4wd then on graven turn left and right and listen for clatter, and clunking to ensure every thing is tight. On dry pavement you can easily tear stuff up. If you have manual hub you can engage the hubs a drive normal or engage the 4wd and not the hubs and drive normal with no issues, auto hubs not so lucky when it comes to keeping ujoints and axles warmed up
Bonanza35
Jan 28, 2014 03:32 PM
mothra
1997 - 2003 F150
Jun 15, 2011 09:37 AM
fornarog
Feb 14, 2006 07:30 AM
dj596
Oct 11, 2005 10:00 AM
ARTURO TOSCANO
Aug 19, 2002 12:43 PM
