Fuel Filter Light
Old Mar 29, 2007 | 07:53 PM
smokey352's Avatar
smokey352
Fuel Filter Light
Ok, if not one thing its becoming to be another, now my fuel filter light is coming on, i changed fuel filter and it still comes on, any ideas ...
Old Mar 29, 2007 | 08:03 PM
bkcowboss's Avatar
bkcowboss
I think that light is turned on by the top sensor on your FPR. Where your FPR bolts to the driver side of the fuel filter there is a screen attached to a plastic piece with a small hole and the a plasic ball inside of there. I believe when that screen/hole plugs up it can cause an eroneus light. if you find the link to steve baz's web page there are instructions on how to clean this screen.
Old Mar 29, 2007 | 08:35 PM
smokey352's Avatar
smokey352
Well, I am not sure now, if I was running out of fuel, even though fuel gauge was not showing empty, would that trigger the sensor ?
Old Mar 29, 2007 | 08:38 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Yes, it could. The sensor is a vacuum senor that is designed to detect a clogged filter causing a fuel flow restriction and increased vacuum in the fuel filter housing.
Old Mar 29, 2007 | 08:51 PM
smokey352's Avatar
smokey352
Ok, because after i replaced the new filter, and ran it, even though the light came on i kept driving it but was afraid to get stuck on road at dark, but i gunned it pretty good several times in my drive, lots of black smoke ( superchip talking) and the check filter light would only come on while idling.
kla94
Feb 3, 2014 08:50 PM
JHoffman93
Sep 18, 2012 05:35 PM
gdog812
15
Nov 26, 2010 04:59 PM
texasjack
Aug 26, 2008 09:49 AM
fordman837000
Feb 9, 2008 09:00 AM
