Replacing Cab Corners
Old Apr 2, 2007 | 11:18 AM
AXracer's Avatar
AXracer
Bonding requires sufficient overlap which may be hard to achieve all the way around with good metal. Welding isn't difficult, I just put in 1 1/2 of my taillights this weekend, look for a post topic and pictures likely later today.
Old Apr 2, 2007 | 11:19 AM
Randy Jack's Avatar
Randy Jack
Originally Posted by Gary E
What about bonding? all the tacks and grinding and hammering and dolly work make me wonder if bonding wouldn't be faster and easier. What are the drawbacks to bonding?
I have done both types of patching. Bonding is an easy way to do some stuff, however, it is totally dependant on how clean you can prep the parts. I bonded the patch skins to the lower section of my doors because I was concerned about warping. I still did some welding when also replacing the lower door pan, but the bonding worked well.
https://www.ford-trucks.com/user_gal...&albumid=25135
The "Trucks" TV show replaced a lower rear cab corner on a Chevy P/U using bonding and showed how to make doublers inserted into the hole, then fit the patch. Looked easier than it really was to do.
ufvj217
Oct 22, 2015 08:07 AM
AXracer
Dec 2, 2014 11:43 AM
stv1991
Mar 31, 2014 04:41 PM
clintonvillian
17
Jan 10, 2014 12:58 PM
cigarxtc
Apr 7, 2011 03:32 PM
