Navigator 4V 5.4
Old Mar 28, 2007 | 08:32 PM
Modified 99's Avatar
Modified 99
Smile Navigator 4V 5.4
What year Navi had the 4 V 5.4 engine?
Old Mar 29, 2007 | 08:16 PM
FTE Herman's Avatar
FTE Herman
1999-2002 I think.
Old Mar 30, 2007 | 07:33 AM
Johnny Langton's Avatar
Johnny Langton
'99-04. '04 was the year of the transition away from it,and none of the '05's had it to my knowledge.
JL
Old Mar 30, 2007 | 10:30 AM
Freak4Ford's Avatar
Freak4Ford
I'm curious as to why Ford switched to the 3 Valve setup on the 2005 models and later? I understand that the 3 valve setup produces only very slight gains in power.
Old Mar 30, 2007 | 10:38 AM
SMIGGS's Avatar
SMIGGS
Production costs possibly? Everything else was or going to the 3V design.
Old Mar 30, 2007 | 11:08 AM
Johnny Langton
Mostly it was a political move. The 3V uses and is tuned to use regular unleaded fuel. The 4V is designed and tuned to use premium fuel,and that was a turnoff to the typical buyer in the market for a large "gas-guzzling" vehicle. It was bad enough to use alot of fuel,but to add the extra costs of premium fuel to the equation,and you scare buyers away.The 4V will make more power/tq than a 3V,but the OE tune has the 4V fairly neutered for making power where the 3V has variable cam timing to help make power.
Old Apr 4, 2007 | 10:11 AM
kitebuz's Avatar
kitebuz
Does the 4v require 93 oct?
JL - do you run 93 oct w/ your custom tuner, or can you program a lower octane setting?
Old Apr 4, 2007 | 11:16 AM
Johnny Langton
Yes,I run premium fuel with my Navigator-it requires premium fuel from the factory.Yes,you could manipulate the borderline knock spark table to run 87 octane,but the savings of $7.00 tank(if it was BONE dry) is offset from the improved economy and power or running 93 octane vs 87 octane.
JL
Old Apr 5, 2007 | 11:55 AM
whotnow's Avatar
whotnow
The 05 3 valve Navi is tuned from the factory to run on 91 or better octane. The manual discurages from using regular gas. But what is the differance between the navi setup and expy of the same year? I watch the factory spit them out of the same assembly line. The code on my 05 navi is CDW5.
Old Apr 5, 2007 | 05:32 PM
Johnny Langton
There's no physical difference in the powerplants,it's all in the tuning. I see that your particular PCM calibration allows spark advance based on the knock sensor input and has 3-4 degrees more ignition spark advance than a regular fuel calibration does.
JL
Old Apr 6, 2007 | 08:53 AM
whotnow's Avatar
whotnow
Does it look like Ford got as much power out of this program as possible? Or should i be looking at the PRP to try and pinch a few more ponies out of it. Right now i am not to happy with the shifting. A little too soft and not enough kick down for my taste.
Old Apr 6, 2007 | 09:21 AM
Johnny Langton
Manufacturers always have to compromise in every calibration-even ones such as the almighty GT. You've got to please CARB, old folks that don't like harsh shifts,and people who are too cheap to use a quality fuel. Plus,you've gotta deal with keeping everything in tolerance for the warranty period.
So yes,I do believe that there are gains to be had-especially in the driveability and transmission functions.
JL
cmiles81
Modular V8 (4.6L, 5.4L)
May 4, 2014 11:58 AM
Xx0573
Jul 3, 2013 11:32 PM
somf
1997 - 2003 F150
Mar 9, 2005 12:51 AM
