Sponsored by: Real Truck
Fuse Block Removal
Old Mar 28, 2007 | 07:30 PM
TchTchr's Avatar
TchTchr
Fuse Block Removal
I thought I'd ask before I break something. How is the fuse block mounted in the engine bay? I need to get the white wire w/ blue stripe "located on the bottom of the fuse block" for the Vegistroke system I'm installing.
Thanks as always!
Old Mar 29, 2007 | 09:42 AM
TchTchr's Avatar
TchTchr
The truck is a 7.3 BTW. I can't figure out how to do signature here.
Old Mar 29, 2007 | 12:17 PM
FN74's Avatar
FN74
Hello, There are 4 metal tabs witch hold that box in place once you have removed the main red power wire lead off the front of that box you will then unclip it from those metal tabs. Pull the whole box up and at an angle so as to get to it from underneath, once you have done so undo the 4 plastic clips that hold the bottom shroud cover on, then all the wires will be exposed. Locate the white with blue, connect the yellow and white with blue then reverse the procedure.
Old Mar 29, 2007 | 02:56 PM
TchTchr's Avatar
TchTchr
Smile
Thanks. Was pretty easy to do. Had I not asked, I probably would have broke something.
sklinemansk
36
Nov 29, 2022 04:12 PM
GamerGirlAlice
Jul 8, 2013 06:13 PM
skibber
WTB - Parts & other
Sep 24, 2011 03:32 AM
windy2965
Jan 26, 2006 04:13 AM
8NRay
Sep 7, 2003 01:16 PM
