Any ideas??
Old Mar 27, 2007 | 03:52 PM
2003 Stroke's Avatar
2003 Stroke
Any ideas??
So here I am w/ my truck at the dealer for the 3rd time in last 20k miles and I am at 95k on the od. and I am still losing coolant after filling until I get down below the min line w/in 150miles and then it stops just below min level. I've heard of readjusting the min level w/ a sticker, but my dealer says my vin is not effected by that tsb....dealer pressurizes and says everythings fine....anyone know if dealer know's what there talking about....here is my vin...1FTNW21P33ED08377....thanks!!
Old Mar 27, 2007 | 04:21 PM
glm racers's Avatar
glm racers
Did the dealer check it when the engine was at operating temp? It sound like either a head gasket or a small pinhole leak somewhere. A head gasket leak would be evident by either water in the oil, which water doesn't compress very well and would make you engine run rough or not at all, or by signs of white smoke from the exhaust. A pinhole leak would be evident by traces of white powder residue from the evapoation of coolant. Also, if the coolant reservoir cap has this powdery residue it will leak coolant from the cap under pressure. If this is the case, rinse the cap with warm water to remove all reisdue and blow dry it before installing it back on.
Old Mar 28, 2007 | 06:00 AM
2003 Stroke
yes they did check at operating temps and still held pressure..i've always had the residue at the degas cap...i do have white smoke at start up, but i've had this since day one and i bought truck new....i just changed oil sunday night and pretty much a qt low like always (dealer just replaced rear main this visit, along w/ the latest flash)...i was hoping someone could run my vin and let me know if this sticker tsb is applicable to my truck....anyone?? just for my peace of mind...thanks!
tony03eX
Nov 25, 2012 02:33 AM
BigGeo
Apr 23, 2009 12:34 PM
z28cookie
Car/truck Buying Advice
Dec 31, 2008 11:26 PM
2003 Stroke
Apr 16, 2007 08:50 PM
reevesg
Modular V10 (6.8l)
24
Jun 9, 2005 08:14 PM
