Sponsored by: Auxito
A/C cuts on/off, only while driving....??
Old Mar 27, 2007 | 08:22 AM
LSUtigers's Avatar
LSUtigers
About every 10 seconds the A/C will cut off, then 10 seconds later will cut back on. It used to do this while in park or neutral, but the dealership "topped it off" and it didn't do it. However, I still notice it cuts on and off when i am accelerating or just driving, but not when at a dead stop in drive.
Any reason why it would do this? I just had a brand new A/C, clutch, etc.. put in September or from this dealership. Supposedly no leaks or anything, blows cold air, but didn't think it was supposed to be cutting on and off??
Thanks!
Old Mar 27, 2007 | 08:42 AM
LxMan1's Avatar
LxMan1
It is presure sensitive, If it is cold, it is ok. As the temp drops in the evaporator, so does the low side pressure. In cooler ambient temps, it will get cold enough for the pressure to drop to the point where the pressure switch will kick out the compressor. This keeps the evaporator from freezing up. At above idle speeds, the compressor turns faster which will create more suction in the low side. It will probably stay engaged when the ouside temps are up in to the upper 80's and above.
Old Mar 27, 2007 | 08:51 AM
LSUtigers's Avatar
LSUtigers
well, it's about 78 defrees right now, should it still be cutting off and on every 10 seconds while driving?
Old Mar 27, 2007 | 09:02 AM
LxMan1's Avatar
LxMan1
Yep. That's what it's designed to do. With the blower on high, it will probably run longer since the increased airflow will keep the evap from getting as cold. Also it will cycle more if run on max a/c once the inside of the truck has cooled down since it is drawing in cooler inside air.
Old Mar 27, 2007 | 11:23 AM
LSUtigers's Avatar
LSUtigers
Thanks Jimmy, for the quick response! I appreciate it
Old Mar 27, 2007 | 11:28 AM
LxMan1's Avatar
LxMan1
No problem. As long as it is cold, I wouldn't worry about it.
banks0531
Aug 10, 2014 08:04 PM
Sally1958
1983 - 2012 Ranger & B-Series
Sep 25, 2011 08:15 AM
johnt471
Aug 27, 2011 06:45 PM
Navigator2008
Aug 21, 2011 12:21 AM
mattdogg02
Jun 15, 2011 10:35 AM
