What rear diff lube?
Old Mar 26, 2007 | 07:57 PM
emptyd's Avatar
emptyd
Question What rear diff lube?
Based on the picture below I believe that My '01 X V-10 has a limitted slip diff. w/ 3.73s. I'm going to open up the diff. this weekend, check out the gears, and re-fill it (maybe w/ synthetic?) but I'm having trouble figuring out what fluid to put in it.
I'm no mechanic so forgive the ignorance - but what else do I need to know to get the correct lube? Dana? (don't even know what that means!)
I tow a 7800# TT. Want it to be ready for the Rockies - any need for a diff. temp. gauge?
Old Mar 26, 2007 | 08:06 PM
TNT in Round Rock's Avatar
TNT in Round Rock
3.5 qts of 75-140 gear oil .. synth if you want .. and you need to get some of Ford's Friction Modifier for the limited slip ..
read this page, very detailed http://guzzle.rbmicro.com/rdiff.html
Old Mar 26, 2007 | 08:17 PM
emptyd's Avatar
emptyd
Thanks!. And thanks also for the link. I love tutorials. Even an idiot like me can sound informed after a quick study!
Not to be dense (oops, too late ) but how do I know that I have a "Sterling 10.5 Rear Differential"?
Thanks again!
Old Mar 26, 2007 | 08:20 PM
TNT in Round Rock
if you have a 3.73 with limited slip, that's what you have ... but you can look at it on the VIN as well under the pinned topic in the SuperDuty section ..
Old Mar 26, 2007 | 08:23 PM
emptyd's Avatar
emptyd
I probably ought to do the front as well with 100K on the truck. I read in posts that there may be a "dana 50" or "dana 60" depending on the year. The above how-to has a link to another how-to on the dana 60. Would it use the same type of fluid if mine is a 50?
You guys/gals are soooo cool! Helping people like me who have little to no experience is a great thing. Might even help to keep me out of the dealership service center and that's always good!
Old Mar 26, 2007 | 08:24 PM
TNT in Round Rock
here's the tutorial on the front diff : http://guzzle.rbmicro.com/fdiff.html
Old Mar 26, 2007 | 08:40 PM
sewerat's Avatar
sewerat
if im not mistaken ALL years of Excursions had a 50 in the front. Monsta would be the one that knows for sure. HE's Da man full of info.
Old Mar 26, 2007 | 08:46 PM
ford390gashog's Avatar
ford390gashog
The diff came with 75w140 synthetic from factory and 4 oz of friction modifier. So if it does have the L/S then you will need the modifier.
