Brakes
Old Mar 26, 2007 | 10:41 AM
AndysFords's Avatar
AndysFords
Brakes
I have replaced everything on my brakes, so I think I have got something that isn't any good. But when I disconnected the vacuum line from the brake booster, I had more brakes. What they are doing is when you push them, they will build up, but as you hold them they leak down under your foot. When I disconnected the vacuum line, they held tight? Does this mean I need a vacuum pump?
Old Mar 26, 2007 | 01:20 PM
Lazy K's Avatar
Lazy K
Does your truck have RABS? You may find you have a faulty RABS valve. When you did brake refit did you bleed the RABS valve(if fitted)?
Old Mar 26, 2007 | 02:54 PM
AndysFords's Avatar
AndysFords
What is a RABS and where is it?
Old Mar 26, 2007 | 08:56 PM
Winger235's Avatar
Winger235
This is your rear anti-lock brake system (RABS) it is a module that is on the driver side mounted to the frame and has 2 brake lines going into it. There is also a small bundle of wires and a plug. It should be right where the frame curves down and the cab mount bracket is. If this unit goes bad or has no power to it you have to overcome it and pressurize it to then pressurize the rest of the rear brakes. This takes a huge stroke of your pedal to even accomplish a couple of pumps or whatever. I took mine right off when it failed and keep my rear brakes adjusted nicely never had a problem.
Old Apr 10, 2007 | 12:33 PM
spanky350's Avatar
spanky350
How did you go about replacing it, with a block or just a compression union? Thanks
Old Apr 10, 2007 | 12:40 PM
Hamberger's Avatar
Hamberger
Vacuum connection do start to leak over time especially on older trucks with hardened hoses and rubber fitting on vacuum line parts and fittings.
A bit of pedal fade is normal for some of the late 80's early 90' trucks I understand. There is a fix somewhere on this forum for that if it bothers you. My 93' has a tendency to fade slowly. It just has not bother me enough to worry about it.
Since you pedal goes hard when you disconnect the vacuum from the booster the problem is most likely booster, vacuum hose or vacuum pump related or possibly a vacuum leak in any of the systems that use vacuum (i.e. heater control valve if you got one)
Seb....
Old Apr 10, 2007 | 07:39 PM
kidoo's Avatar
kidoo
I just had my Master Cylinder replaced with a Ford F 450 one. There is a Ford bulletin on this. The brakes feels quite better than before, firm and would not sink down, and the truck brakes much better. I had a 93 before and there was also always a little sinking, not to worry, but still anoying.
My problem is that the dam light is still on. I drove for about ten miles and the light went off. The mechanic told me he could not bleed one of the rear wheel cylinder and the valve you are talking about could not be bled because the bleeder is broken off the valve.
In my Haynes book they talk about a pressure differential valve and a RABS valve. I do not know what I have. I know I have a valve with lines connected to on the driver side. The books says that the pressure diffential valve have to be recenter if there is a leak of if you replace a component on the brakes.
I am really sick of that system, and sick to work on the truck in the driveway. I will take it back tomorow and let you know what else they find, probably a coupe of 100$ later.
Old Apr 11, 2007 | 08:39 AM
Hamberger's Avatar
Hamberger
I had the same experience when I last tried to bleed my 93' rear brakes with the O.E.M. cyliders. Both bleeder valves were rusted solid and I could not get them to move. Ended up buying two new cylinders. I eventually got one of the two bleeder valves on the old cylinders to move by dis-assembling it on the bench and applying some heat. The other one was hopeless and just broke off.
I put lots of nickel antiseize on the new bleeder threads on the new cylinders so hopefully they will move the next time I need to use them.
The O.E.M. cylinder did not have a very good bleeder screw design if you ask me.
Seb....
Old Apr 11, 2007 | 04:24 PM
kidoo's Avatar
kidoo
I just drove the truck today, brake lights staid off all the time. The F 450 MC really made a difference. When you apply the brakes, what a feeling, firm, no sponge, no sinkin. Hopefully the problem is fix. May be there was a bubble in there that found a place to hide...
