1996 f-250 problem
Old Mar 25, 2007 | 10:42 PM
fsbigcountry's Avatar
fsbigcountry
1996 f-250 problem
Can anyone tell me how to check to see if the catalytic converter is stopped up. This is one of the things i need to check for. My truck is feeling like it is not getting fuel sometimes. The truck starts surging, missing, hesitating. I have already changed the fuel filter. Before I go to Tyler Fuel Injection I want to make sure my eshaust is clear. Thanks. 96 f-250 5.8 351 207k miles.
Old Mar 25, 2007 | 11:12 PM
unixadm's Avatar
unixadm
You can hook a vacuum gauge to the motor, but the real test is to have a bung welded into the exhaust between the manifold and the cat, and then hook an exhaust back pressure gauge to it and see if the cat/muffler is restricting flow. If the vehicle had dual exhaust you could put you hands over both sides of the exhaust and see if one flows less than the other. I have a 2003 Crown Vic Police Interceptor that has a slightly plugged cat on the passenger side and it saps the power out. It causes the motor to rev slower and cuts down on fuel econmy. I can feel the difference in exhaust flow from side to side.
Old Mar 25, 2007 | 11:15 PM
gustang818's Avatar
gustang818
Disconnect the exhaust from the manifolds. If it runs better, then you have restriction in your exhaust. If it doesn't you have to keep looking for your problem. Have you checked your fuel flow?
Old Mar 25, 2007 | 11:33 PM
Bruce R Leech's Avatar
Bruce R Leech
you can pull the O2sencer and check the presher also.
Can anyone tell him what the reading should be?
Old Mar 25, 2007 | 11:35 PM
Bruce R Leech
that is a lot of work and noisy also.
Old Mar 26, 2007 | 05:56 AM
fsbigcountry
What do I do if it is stopped up? Can I do away with it?
Old Mar 26, 2007 | 11:42 AM
gustang818's Avatar
gustang818
If you live somewhere that does emissions testing, no. They used to sell something called a "test pipe" that could be placed where the cat was. Some people fabricate their own. A muffler shop won't do it because there can be big fines. I have also heard of people who have gutted their cats. When I was at Advance Auto yesterday there was a guy buying a "universal cat" and the cost was about $70.
Old Mar 26, 2007 | 04:59 PM
andym's Avatar
andym
Based on the description of the symptoms, the exhaust is not the problem.
I would start with a tune-up. Then pull the codes and go from there.
Old Mar 26, 2007 | 08:22 PM
jroehl's Avatar
jroehl
I'm with Andy. Cats generally don't plug suddenly. Once they start to plug, you lose top-end power. You may not even notice at city speeds, but you'll notice it bogging down at upper engine speeds first.
Jason
Old Mar 26, 2007 | 09:18 PM
Bruce R Leech
what presser should you get at say 2500 rpm no load?
prdiener
Oct 4, 2013 01:54 PM
nchoffar
2009 - 2014 F150
Jul 1, 2013 12:03 AM
Scaper
Apr 28, 2012 06:37 PM
altruego
May 17, 2011 04:04 PM
Fire_420
Feb 3, 2010 03:44 PM
