Not Grounding?
Old Mar 29, 2007 | 06:58 PM
Bear 45/70's Avatar
Bear 45/70
The starter voltage does not run thru the frame or body. Ground from battery to engine block, to starter. Positive from battery to solenoid, from solenoid to starter. The power to activate the solenoid is very little current and runs from battery to ignition switch to solenoid. Ground is from solenoid base to fender, to firewall to block and back to the battery. Again solenoid is very low current compared to the 70 to 120 amps the starter draws.
Old Mar 29, 2007 | 08:35 PM
FordF350Baby's Avatar
FordF350Baby
hmm, well what ever got replaced has correct the issue.
