460 Torque Numbers
Old Mar 28, 2007 | 08:52 PM
nickc84's Avatar
nickc84
460 Torque Numbers
can anyone run a desktop dyno?
i've got a 76 460 with stock crank stock rods, bored .30 over
sealed power h535cp.30 pistons
D3VE Heads, no porting done, milled .15thousands to clean up
stock valves
compression should be 9.2-9.5
Edelbrock Rpm Intake
Stock Exhaust Manifolds/Possibly thinking headers, but $425-525 is alot
Holley 670 Street Avenger Carb
MSD Dist, 8580 no vac adv.
MSD Igniton 6al, msd coil
Cloyes older timing gear set, straight up timing
all new stuff, never been started. just wondering what it could/should make? looking for 500 ft. lbs torque. hoping
thanks
nick c from fla
Old Mar 29, 2007 | 06:14 AM
79superduty's Avatar
79superduty
A cam grind would help!
Old Mar 29, 2007 | 06:54 AM
nickc84's Avatar
nickc84
forgot to put that in
its the edelbrock cam,
2167* 272° 282° 194° 204° 0.265 0.28 0.46 0.48 8° ATDC 22° ABDC 37° BBDC 13° BTDC 110° 105°
thanks
Old Mar 29, 2007 | 09:49 AM
darrin1999's Avatar
darrin1999
around 435-440 ft-lbs
if you did some good exhaust porting and ran headers and put the stock intake back on you should probably have your 500 ft-lbs
Old Mar 29, 2007 | 12:23 PM
bhardy501's Avatar
bhardy501
You can get a good set of headers through Summit for aroud $170.00. I think mine are Hookers for a 2 wheel drive 74-80 ( not absolutely positive about years covered) with automatic. I gave around $170.00 for them and they work great. Use the aluminum gaskets on the heads and the collectors and you wont have to worry about leaks.
Old Mar 29, 2007 | 04:38 PM
nickc84's Avatar
nickc84
is your truck a 4x4 with a 460? i've heard rumors that you could use the 2wd headers, but i never saw them actually used. mine is 78 f250 4x4 with d44 fa
and darinn1999 did u use desktop dyno? cause in the edlebrock catalog they had a stock 460 with 8.5 comp, which is stock, their cam, their intake, and 1 3/4 headers and it had around 460-465 ft. lbs torque at 2500, theres no way that i cannot have those same numbers with a better timing chain and all new stuff, i should have more due to increased compression also, but i dont have the program either. thanks for the help
nick
Old Mar 30, 2007 | 02:52 AM
darrin1999's Avatar
darrin1999
yep, ive got dynosim with protools. manifolds and stock exhaust ports hurt alot... yours came in with 300 horse and 440 torque
