Not Grounding?
Old Mar 25, 2007 | 08:03 PM
FordF350Baby's Avatar
FordF350Baby
Not Grounding?
Some of you may recall me having tough times with my truck starting. The 1995 F350. Anyway, today I went to start it, and it did its usual slow whind up, but for the first time it wouldnt start, then I see smoke coming out from under neath the hood and through the vents in the truck. I go to lift the hood and there I found a wire that was going from the motor to the back of the firewall. I am pretty confident it is a grounding wire. Now it had gotten so hot it had melted the insulator right of the wire. So I snapped tide if away from the motor where it had been laying, and then it started right up. What would cause this? Is it the grouding motor that had been sitting on the engine block, or did it short or something? Could this be the rout of my entire starting problem?
Old Mar 26, 2007 | 12:25 AM
Bear 45/70's Avatar
Bear 45/70
A ground wire touching ground (the engine block is ground, just like the truck frame)thru burnt isulation will hurt nothing and can't cause you the problem you have described. A bad connection or dirty connection will cause it. Then the starter solenoid or the starter.
Old Mar 26, 2007 | 03:59 PM
FordF350Baby
huh, okay,,,,
Old Mar 27, 2007 | 04:44 AM
darrin1999's Avatar
darrin1999
it could be a fusible link... i had one fry on my old grand marquis (5.0 mulitiport) and it would do the same thing... it looked just like a regular wire only one day it melted the casing off... replaced it and it worked fine
Old Mar 27, 2007 | 12:00 PM
Bear 45/70's Avatar
Bear 45/70
There are no fusible links in the starting system or the grounding system.
Old Mar 27, 2007 | 09:16 PM
FordF350Baby
stange stuff. Its just an annoying kind I would like to get out. Its kind of embarrassing because the truck is really nice looking and it makes a scene everywhere, and everyone is watching, but then I go to start it, and it barely starts, and everyone is confused and dissapointed for such a wierd start, but furthermore, its very annoying for me. I am getting it looked at tomorrow tho,
Old Mar 27, 2007 | 09:55 PM
Bear 45/70's Avatar
Bear 45/70
Have you had the starter checked? I've seen them do this kind of thing, plus how big is the battery (Cold Cranking Amps) and is it fully charged? To small a battery capacity or a weak or undercharged battery will do this. As the voltage drops the current goes up, creating heat (melting wires, etc.) and frying wires and motors.
Old Mar 27, 2007 | 11:43 PM
darrin1999's Avatar
darrin1999
my roommate borrowed the car the day the fusible link went... he also fried the alternator... that was the last time he got my keys
Old Mar 28, 2007 | 10:18 AM
FordF350Baby
Rough...No the starter hasnt been checked. The battery is a big one, and its only a not a year old yet. I will be extremely angry with the dealer if this starting problem is the starter., and not some compression issue with the coolant leak. Absoluetly a discuss.
Old Mar 28, 2007 | 07:00 PM
jim henderson's Avatar
jim henderson
Sounds like a power wire to the starter solenoid. I had one where a camper dealer ran a wire to the starter solenoid to supply power to the camper lights. That wire eventuallshorted to ground and started smoking right against the firewall near the solenoid. If any of the solenoid wires touch ground, you got a short and potential fire.
Just a thought,
Jim Henderson
Old Mar 28, 2007 | 08:37 PM
Bear 45/70's Avatar
Bear 45/70
Just a thought,
Jim Henderson
The thought should be that any wire that has Battery 12 volts plus on it when shorted to ground is gonna be a bad thing. But either the wire fries (small gauge wire) or or the battery blows up or goes dead. But not a slow crank for the starter, just isn't how electricity works.
Old Mar 29, 2007 | 12:11 AM
soloquest's Avatar
soloquest
Talking
Sounds like the wire that burnt was a secondary ground wire from the engine block to the cab, which means the main ground wire from the battery to the block has a bad/intermittent connection and all the current went through the small wire instead of the battery ground cable when you tried to start it, which also acounts for a slow starter motor.
My 2 cents
Jon
Old Mar 29, 2007 | 01:27 AM
Bear 45/70's Avatar
Bear 45/70
My 2 cents
Jon
Agreed these problems are almost always a bad connection or a bad starter.
Old Mar 29, 2007 | 06:06 AM
FordF350Baby
Thanks guys. Also is this strange to you? When I i opened the hood after that incident, it seemed like everytihng was very hot. Even the tubes from the cold air intake to the throttle body were extremely warm, arnt those just suppose to be cool? Maybe a little hot from engine heat, but not that hot? Did all that weird electriccity do alot of weird transfering throughout the motor?
Old Mar 29, 2007 | 06:46 PM
FordF350Baby
Got her back today. My guy said the negative ground wire was had been holding on the frame by two or three strands of wire, he was astounded to see how the truck continued to start with only that much amps going through that tiny amount of wire. Shes all set tho now.
