System Too Lean error codes
Old Mar 25, 2007 | 12:38 PM
Truck Issues's Avatar
Truck Issues
Smile System Too Lean error codes
Hi,
My '98 Ford Explorer indicates 171 & 174 error codes, Bank 1 and Bank 2 System Too Lean. Is this caused from a bad upstream or downstream sensor?
Can you tell me where both downstream and upstream sensors are located (ie. driver side, between the manifold and the converter) I have 4 and am not sure which to replace? Is System Too Lean related to lack of Air or Fuel?
Will the errors cause the truck to keep stalling when I come to a full stop?
Thanks,
Patrick
Old Mar 25, 2007 | 12:48 PM
Beast12's Avatar
Beast12
Thread moved to the Explorer forum.
-Matt
Old Mar 26, 2007 | 11:21 AM
aquanaut20's Avatar
aquanaut20
these codes indicating lean on both bank usualy mean that you have a leak at the intake manifold, Look for broken, loose vacuam hoses and test for leaky gaskets.
Old Mar 26, 2007 | 08:15 PM
Truck Issues
Thank you for the reply! I'm sorry for the incorrect forum as I've looked for Explorer Forum without success.
Thanks...
Old Mar 26, 2007 | 10:08 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
This code is almost NEVER caused by a defective O2 sensor, and when it is, there are usually other codes present.
Your lean codes are almost always caused by a vacuum leak, or a dirty Mass Air Flow sensor. Check the basics... vacuum lines, hoses... PCV valve... spray some carb cleaner around the intake area while the vehicle is running and listen for an idle change.. if it changes then you just sprayed where the leak is!
If nothing comes up, remove your MAF and clean the elements using brake cleaner or intake cleaner spray.
If that doesn't fix it then replace your intake gaskets.
Good luck
82inline6
Jan 14, 2014 11:04 PM
Russpf
Modular V8 (4.6L, 5.4L)
May 13, 2010 03:29 AM
econo666
Oct 29, 2005 11:42 PM
wshniwuzfshn
1997 - 2003 F150
Oct 25, 2005 01:12 PM
01silvergt
Jul 13, 2005 02:08 PM
