Added Optima Yellow Top
Old Mar 25, 2007 | 10:06 AM
is300wrx's Avatar
is300wrx
My OEM battery, almost 2 years old, does a pretty good job powering all my accessories- back up sensors, back up camera, LED bar, fog lights, Garmin navigation, Edge, radar, moderate audio system. But now, with this yellow top, I consistently hit 14.2-14.3 according to Edge (while driving) and 14.4 with a meter while its idle. Great great battery and I recommend it to all off roaders since its a dry cell battey and you can mount it upside down, sideways, upways, whatever way you want and shake and shake them up.
Only downside is that it cost me $200 after taxes....I guess its not that bad because you get better performance than any other batteries in the industry as well as they last twice as long as liquid batteries.
Old Mar 25, 2007 | 01:34 PM
MBBFord's Avatar
MBBFord
Just currious, what are the specs on the yellow top? CCA? ect...
I was looking at either a odyssey or a optima for my Bronco's soon to have winch, and both are around the same price range.
Old Mar 25, 2007 | 01:41 PM
is300wrx's Avatar
is300wrx
I think the OEM was 660CCA....the optima is around 750CCA
Old Mar 25, 2007 | 02:00 PM
Tom's Avatar
Tom
Okay, this may seem like a dumb question here, but....
if your OEM battery powers everything just fine........why replace it?
Unless that $200 was burning a hole in your pocket...
Old Mar 25, 2007 | 02:24 PM
96f150's Avatar
96f150
Cool deal. The only really downside of the optima batteries are they have a limited range, which means they have a lower reserve capacity. Did they give you a warranty with it? B&B Performance seems to have the best pricing I have seen.
Old Mar 25, 2007 | 02:26 PM
wildcard30's Avatar
wildcard30
Your OEM battery should have been fine...
I would have opted for a high output alternator.
The 14.4 and the other reading you are seeing with the truck run is the votage the alternator is outputting...
You can account for part of those number because your battery is new.
Old Mar 25, 2007 | 06:42 PM
dans67's Avatar
dans67
Good luck on that one. I've dealt with many of these batteries, and they don't last very well. The yellow tops generally some with a one year warranty, and a large percentage of them need it.
Old Mar 25, 2007 | 08:03 PM
bsocko's Avatar
bsocko
I bought a red top, was the best money I even spent!
Old Mar 26, 2007 | 09:44 AM
is300wrx's Avatar
is300wrx
I am not too fond with B&B and AutoZone actually had the YellowTops in stock. The prices were the same so it was no brainer for me. Plus, B&B is very far from where I live.
These batteries DO last. My buddy has a serious sound system: Pioneer Z1 head unit, Alpine Type R components all around, 2- 12"Alpine Type R subs, and all the door/subs are powered by amplifiers (4amps), and he has 2 capacitators to help him out. He has in there one yellow top in the rear where the spare tires used to be, and a red top under the hood. His battery has never failed
Old Mar 26, 2007 | 09:58 AM
Tom's Avatar
Tom
But....that has nothing to do with the battery!
If you are drawing more power than the alternator can supply, it will drain the battery. Then, when you shut your stuff off, it'll be recharged by the alternator.
If you are getting 14.x volts constantly, then it is NOT draining the battery at all, meaning your expensive Optima is sitting there fat and happy, not giving out any juice. The ALTERNATOR is still pushing all your electronics. The only time the battery ever supplies power is either
1. when starting the truck
2. when aftermarket accessories exceed the alternator's capacity
And if the aftermarket accessories exceed the alternator's capacity for too long, regardless of the battery used, it WILL discharge, your truck WILL stall, and you WILL need to be jump started.
IMO a high capacity alternator is a better choice if you are trying to push a big sound system or lots of accesssories.
Old Mar 26, 2007 | 11:30 AM
gui88ford's Avatar
gui88ford
yes, alternator if you need more power....it's not like your tring to start a 700 HP engin or something.....just watch your volts meter....if that drops below where it should because you have lots of stuff on your truck then your using the battery and it's time for a upgraded alternator....not a new battery...
Old Mar 26, 2007 | 07:16 PM
baitmaster's Avatar
baitmaster
In this part of the the world, if you get 3 yrs out of a battery, consider yourself lucky. In my 28 yrs in the desert, the majority of the batteries I have had to replace didnt make it past the second summer. Especially the "sealed" batteries. No way to get any water in them. I have a used Red Top Optima in my 390 '72 that hasnt given me any probs for 2 yrs, so we'll see. I have had it run down a couple of times for different reasons, but I like the fact that it recharges so quickly. The '05 still has the OEM in it, but have been considering changing it out before I get stranded. (Or maybe I'll just carry my spare Everstart in the back when I take a trip.) When you get back in the mountains all by yourself, you never know. Murphy's law and all.
Old Mar 26, 2007 | 09:47 PM
is300wrx's Avatar
is300wrx
yea...I mean yea as far as starting goes, it starts MINT. The "old" battery, even though it may have been good, it did hesistate at times and especially if I left it on ACC for about 10min playing the radio. I love my battery
Old Mar 26, 2007 | 10:55 PM
edgl's Avatar
edgl
I use Optima batteries in generators, and in my vehicles. They work very well, and last a long time. recharge in half the time of regular batteries.
Old Mar 29, 2007 | 08:00 PM
BII Plow Truck's Avatar
BII Plow Truck
I run Optimas in everything I own, and would not buy anything else....well at least not for 12 years!
