I6 flywheel interchangeability
Old Feb 27, 2020 | 03:51 PM
lazybullfrog's Avatar
lazybullfrog
4wd Low
These part numbers work for a new 164 tooth flywheel with zero imbalance and drilled for both 10" and 11" clutches for Ford internally balanced engines such as the 240 and 300 i6.
LuK #LFW132
NAPA NCF #88132
Hope this helps someone.
Old Mar 8, 2020 | 02:02 PM
Ron/RPMS's Avatar
Ron/RPMS
It has been awhile since I put the 300 in my 84 f350 but I believe the bolts for fastening the pressure plate(PP) to the flywheel are 5/16-18 and by looking at the service manual it says to torque them 20 to 29 ft-lbs I believe this to be true. In racing applications the long/Ford 11 inch style clutch mounting holes are drilled out to fit a 3/8 bolt. We use 3/8 studs to mount the PP with close tolerance to keep runout between the PP and flywheel to a minimum. On 5/16 stuff we even counterbore the mounting hole 1/8 to 3/16 and let the smooth shank of the bolt locate the PP.
I said all that to say this when replacing a PP make sure the hole in PP is no bigger than 1/64 of the shank of the bolt. 5/16 screw = 21/64 hole, 3/8 screw= 25/64 hole. A 25/64 hole with a 5/16 screw will let the PP move approx 5/64 to one side and cause an imbalance.
Just my experience ron....................
Old Apr 25, 2020 | 12:33 AM
HydroDog's Avatar
HydroDog
LuK #LFW132
NAPA NCF #88132
Thanks for the tip,Im heading to NAPA tomorrow to check it out.
Old May 27, 2024 | 08:59 PM
drm4633's Avatar
drm4633
LuK #LFW132
NAPA NCF #88132
This helped me in 2024. Flywheel fit my 66 240.
​​​​​​LuK 11" clutch 07-027 also fit.
Got both from rockauto for $176.
WindBlue72
Mar 27, 2016 04:40 PM
WilliamKG88
19
Jun 9, 2015 02:09 PM
OUR66F100
May 22, 2009 09:26 PM
todd jo
Mar 25, 2007 02:11 PM
broncoman66
Feb 2, 2003 03:31 PM
