1978 - 1996 Big Bronco
Simple job now an epic....help!!
Old Apr 24, 2002 | 08:17 AM
djbaines's Avatar
djbaines
I detached the shifter cable from the shift lever on the side of the tranny, ('92 XLT, E4OD), while replacing a part. I would have thought that I'd then be able to freely move the shift selecter inside the truck from Park all the way down to 1. I can freely move it between park and reverse but that's it. It won't go beyond reverse. Is something on the column blocking the shifter, or do I need to do something at the end of the cable where it connects to the rod? Pushing on the brake won't help either.
Anybody know anything about this?
Old Apr 26, 2002 | 06:57 AM
greengoblin's Avatar
greengoblin
I take it that the key is on and you tried to pull the lever toward you as if you going to drive it. it has a safety indent so you can't slam from r-d and d-r accidently thus scewing up the tranny.just check it out simple little duhs stump the best of us. hope this helps.
The greengoblin
83 bronc
Old Apr 26, 2002 | 10:50 AM
bgblktruk's Avatar
bgblktruk
Mikec35
Sep 14, 2014 10:17 AM
secondechomatt
Aug 15, 2013 03:29 PM
FordMaverickFan
May 24, 2012 09:03 PM
RVABigGreen
Jun 27, 2010 04:32 PM
chanman17
Apr 5, 2010 10:42 AM
