Anyone know off hand which color is the 12v+ on the CD6 in an 06??
I am thinking it's the green w/ purple stripe, but I don't have a meter to test it. Got my dash off and just trying to find a suitable switched power wire to hook up a PIE AUX adapter. Green w/purple is on the plug above the radio fuse and present on the back of the radio, so my superslueth skills are suggesting that one.
If all else fails I will tap the powerpoint, but I would rather have it switched.
It usta was that the power center (fuse panel) had several blank unswitched points, just check hot side with digital mm, key on, and then off, when one checks out as switched, but is unused, an appropriate fuse can be installed and then wire in your accessary. I have not checked a late model to see if the power center still has unused points.
Radio 12v lt. green/purple + radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
