engine light
Old Mar 24, 2007 | 12:01 AM
dantheman88125's Avatar
dantheman88125
engine light
ok so the other day i was driving and the check engine light just came on. the truck runs fine and everything seems to have no problem. i was wondering if ford has it set to come on when u reach 35000 miles. does anybody know if this is true?
Old Mar 24, 2007 | 05:41 AM
Rockledge's Avatar
Rockledge
The light only comes on when there is a problem. You can get the codes pulled at Autozone.
Old Mar 24, 2007 | 06:23 AM
cdncowboy's Avatar
cdncowboy
does it come on and off ?? prolly is a O2 sensor
Old Mar 24, 2007 | 07:11 PM
dantheman88125
it has stayed on for the past two days. i went to auto zone to use there scanner but they wanted a 150$ deposit and i didn't have that kind of money. i will just take it to the dealer where i bought it
Old Mar 24, 2007 | 07:44 PM
rds4ou's Avatar
rds4ou
Why would they need a deposit to scan the dtc? They offer the service for free.
Old Mar 24, 2007 | 08:15 PM
dantheman88125
ion they wouldnt do it for us. what ever it is it is causing me to get horrible gas milage
Old Mar 24, 2007 | 08:22 PM
rds4ou's Avatar
rds4ou
Are you still in warranty? If you are not i think they charge quite a bit to do it
Old Mar 24, 2007 | 08:30 PM
Rockledge's Avatar
Rockledge
I believe CA doesn't allow parts store employees to pull codes, now that I think of it.
You need to get the codes pulled somehow.
Old Mar 24, 2007 | 08:51 PM
pawpaw's Avatar
pawpaw
Your right Rockledge, Calif has a law that say if the store pulls the codes, they have to charge.
BUT their charge is refundable, in this case, so a redit card would do.
If he doesn't have that option, then buying a code reader would likely be less costly, or perhaps not more so, than going to the Dealer.
Or maybe there is a FTE Chapter close by, with a member that has a scan tool or code reader, that could do it at no cost.
Just a couple more thoughts for pondering.
Old Mar 24, 2007 | 09:05 PM
arnold parrett's Avatar
arnold parrett
Unhappy 94 ranger 2.3l cel on
I Keep Getting A 121, & 172 Code. What Do They Mean And Where Are They Located To Fix. Thank You!
Old Mar 25, 2007 | 08:37 AM
rds4ou's Avatar
rds4ou
172 is bank one running rich and the 121 is a tps circuit problem.
Old Mar 25, 2007 | 09:27 AM
pawpaw's Avatar
pawpaw
Welcome to FTE Arnold.
I read the 121 code as Throttle Position Senor (TPS) voltage does not agree with Mass Air Flow (MAF) sensor.
172 = System adaptive fuel too rich (bank 1)
Your TPS is on the throttle body. The MAF sensor is in the air tube, just past the air filter.
You should begin a new thread, by going to the front page of this forum & clicking on "start new thread/discussion" so you can get answers just for your problem/s.
BTW, be sure to check the "Technical Information" thread, located atop this forum's front page, it's loaded with all kinds of helpful repair info, as well as links to trouble code number meanings.
alecams99
Jan 29, 2013 11:08 PM
boblewis
Mar 2, 2012 07:58 PM
baronvonwagner
Jul 1, 2009 07:35 AM
Dustin_86
Dec 2, 2006 05:40 PM
bmxerbrett
Jan 29, 2006 08:07 PM
