Sponsored by: Real Truck
Misc. sound
Old Mar 23, 2007 | 07:19 PM
dludlow's Avatar
dludlow
Misc. sound
'06 V10 250 - 16000 miles
Everyone knows the snap, crackle and pop sound our exhausts make when we turn off the truck and walk away.
Problem is, truck is making this sound everytime I stop at a light, sit idle, etc... even is popping and cracking as I drive alongside a jersey-wall and the sound reflects back into the cab.
What is causing this? Do I have something that needs to be looked at?
Thanks guys/gals... love the site! Tremendous resource!
Old Mar 23, 2007 | 07:32 PM
bpbell1's Avatar
bpbell1
Hello, my truck had same problem, just got it fixed, seemed to be the solution. Found the fix here:
TSB
06-20-8 EXHAUST SYSTEM NOISE - SNAP / POP / TICK / PING - 5.4L AND 6.8L ENGINES - VEHICLES BUILT ON OR BEFORE 9/8/2006
Old Mar 23, 2007 | 07:49 PM
dludlow's Avatar
dludlow
TSB
Where did you find the TSB? I cannot find it in those on this site.
What was the issue with your truck? What did Ford do to fix?
Thanks!
Old Mar 23, 2007 | 07:58 PM
bpbell1's Avatar
bpbell1
Up top on the screen there's a Recalls/TSB section. Scroll down and I found it under my truck, which is an 06 250. When you're there, you should see the specific TSB near the bottom, just look for the matching header. I was frustrated by the same sound and techs telling me it's heating/cooling, which didn't seem right all the time while driving, so I searched around the TSB's and came across it. I printed up the TSB report, brought it to my local dealer and told them that was my problem, which they had no problem fixing with little question.
Old Mar 23, 2007 | 07:59 PM
bpbell1's Avatar
bpbell1
You're welcome, hope this works for you.
Old Mar 23, 2007 | 08:06 PM
dludlow's Avatar
dludlow
Found it, will be taking to the shop over the weekend! Thank you kind Sir!
Did the shop have anything to say about it? Simple fix no hassle?
Wish they would pay to put a nice exhaust on for me
Old Mar 23, 2007 | 08:34 PM
bpbell1's Avatar
bpbell1
Talking
It was an easy fix, but took a couple days to get the parts in. Gotta run for now, good luck, let us know how it works for you.
Old May 2, 2007 | 07:54 AM
dludlow's Avatar
dludlow
Well... finally free'd up at work to where I could be without the rig for a day.
Called the dealership ahead of time, was told they would order the parts to do this exhaust TSB job. 6 hours later and after only an oil change they call to tell me they had to order the parts to do the exhaust replacement.... THANKS FORD!
Again, great truck, crappy customer service!
URDADDY
6.4L Power Stroke Diesel
Feb 10, 2014 11:37 AM
Dorito
Mar 2, 2013 04:47 PM
fordpride
27
Sep 26, 2010 05:20 PM
rustyjones14
Aug 23, 2010 10:03 PM
bsr2002
Aerostar
May 19, 2010 07:26 AM
