idler pulley
Old Mar 23, 2007 | 10:13 AM
highboy390fe's Avatar
highboy390fe
idler pulley
I have a 93 e350 with the 7.3 diesel, the pulley is shot and needs to be replaced the bolt is stripped out and i cannot get it out. Is there a bracket i can take of and replace to get this out or what do you guys think I should do. Thanks
Old Mar 23, 2007 | 01:22 PM
PLC7.3's Avatar
PLC7.3
The idler bolt I believe goes into the block........ Short of grinding off the torx head, then disassembling the rest to see what is going on.......
Old Mar 23, 2007 | 06:24 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Wonder if he drilled it and used an "easyout" on it. It would take a very short drill and a 90deg head to do it. What do you think PLC7.3
Old Mar 23, 2007 | 10:10 PM
PLC7.3's Avatar
PLC7.3
It would be pretty hard to hold it while drilling and I think it would be a grade 5 or 8 bolt ???? With the Torx head it would be hard on drill bits for the first while.
mudboggin3
Nov 8, 2013 10:47 PM
todathome
Sep 12, 2013 10:08 PM
Evan_P
Nov 9, 2012 06:13 PM
sowaxeman
May 19, 2009 09:06 PM
RangerPilot
1983 - 2012 Ranger & B-Series
Dec 3, 2006 01:52 AM
