Modular V10 (6.8l)
help please!!
Old Mar 29, 2007 | 11:59 AM
biz4two's Avatar
biz4two
Arrow
Just a tip regarding the cat issue...
Might want to look at a MagnaFlow Direct-Fit catalytic converter. They are available from Summit...and I think they will ship to AK.
I understand the OEM pricing, so MagnaFlow is a good alternative.
biz
Old Mar 30, 2007 | 12:31 AM
ibleedfordblue's Avatar
ibleedfordblue
Originally Posted by V10_Cougar
That happened to me once. I just added Di-Electric grease to the boots.
Ibleedfordblue, how are your coil boots.
all of the boots are new. and they all have die-electric silicon in them. i have used it for over 10 years on all plug wires. the problem was there before i changes the plugs and coils and is still there. although it does have more off the line power it still loses it at 3500 in all gears. just bogs out and wont climb any higher unless i back out of it and let it shift gears. it is driving me nuts. i have checked all of the basics.
ibleedfordblue
biz
i have discover that and that is what i am going to use. thank you a bunch though.
Old Mar 30, 2007 | 12:51 AM
FortyFords's Avatar
FortyFords
You did a fuel psi test underload while driving ?
Being the quality of our fuel nowadays its possible that the pump sock in the tank is clogged or the pump is going bad.
and has the epc pressure been chk at the tranny?
Rich
Old Mar 30, 2007 | 07:49 AM
dkf's Avatar
dkf
Check out Jeg's as well they can be quite a bit cheaper than Summit. I bought my cat from Jeg's and saved $30 over Summits price. www.jegs.com
No big deal about punching out cats. During the 70's and 80's it was a common occurance around here.
Old Apr 1, 2007 | 01:22 PM
ibleedfordblue
just recieved a new tool, TRAN X 2000. IT CAN TEST ALL ELECTRICAL COMPONENTS OF THE TRANNY. ALREADY HAVE THE PRESSURE GAUGES. i am going to have fun with this. it can test them on the bench!! as soon as i can get the truck back in the shop i will thoroughly check it out again. thanks for all the feedback guys.
Old Apr 1, 2007 | 01:30 PM
Monsta's Avatar
Monsta
Sit. Stay.
But have you check the fuel system like Forty and others have suggested? This sounds like a classic fuel pump problem.
Old Apr 1, 2007 | 08:54 PM
ibleedfordblue
fuel pressure is 35-36 at idle. runs about 38-40 under a full load.
Old Apr 2, 2007 | 01:15 AM
Monsta's Avatar
Monsta
Sit. Stay.
And what does it do when it starts to miss at 3500?
Old Apr 3, 2007 | 05:27 PM
ibleedfordblue
well it turns out that the accel coils i put on it were crap. 6 out of 10 failed. went to ford and got oe coils and motorcraft plugs and it now runs great!
Old Apr 3, 2007 | 05:50 PM
Fredvon4's Avatar
Fredvon4
I bleed blue
this comment is NOT directed at you!
We been saying for years here that the MotorCraft stuff WORKS!
Dang it! LISSEN UP..... quit tossing your money at all the fancy dancy doo dads... most of the time they are just hyped up crapola! The Factory MotorCraft stuff WORKS! and it is not dramatically more expensive...in many cases it is much less expensive
Old Apr 3, 2007 | 06:47 PM
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by ibleedfordblue
.... the accel coils i put on it were crap. 6 out of 10 failed!
'oly chit mayn!
Old Apr 3, 2007 | 08:54 PM
  #28
NoMo's Avatar
NoMo
I know it's tough to believe that a brand-new "whatever" that you just installed is bad. Even more difficult to find that 60% of "whatever" was bad.
Glad you found the problem and was able to fix it relatively cheaply.
Old Apr 3, 2007 | 10:01 PM
  #29
FortyFords's Avatar
FortyFords
As we all have said before 75% of this aftermarket crap is not worth the time an effort to install it.
Wish we would have known ,might have been able to save you some grief.
Glad your fixed
Stay away from aftermarket plugs also
Rich
Old Apr 5, 2007 | 02:55 PM
  #30
biz4two's Avatar
biz4two
Thumbs up
Glad to hear your fixed and running!
I'm really shocked that 6 out of 10 would have failed so soon. I have just scratched Accel off the list of good parts. Thanks for reporting back with the fix.
biz
StarfishFD
Feb 6, 2016 05:52 PM
87_f150_5oh
33
Nov 10, 2015 06:38 AM
BigDoug
Mar 31, 2015 10:57 AM
earlschieb
Modular V8 (4.6L, 5.4L)
May 10, 2008 09:20 AM
shagz
1983 - 2012 Ranger & B-Series
Dec 9, 2000 01:57 PM
