Oil recomendations
Old Mar 22, 2007 | 04:17 PM
Ranger1F150's Avatar
Ranger1F150
Oil recomendations
So I just bought a 79 Bronco with a 351M from a guy on here. Looks like he took very good care of it. I was wondering what kind of oil I should run with (I think)160K miles on it.
Old Mar 22, 2007 | 06:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
Diesel engine oil, 10W30 or there abouts.
Old Mar 23, 2007 | 08:55 AM
Ranger1F150
Diesel oil in a 351M gas ?
Old Mar 23, 2007 | 09:49 AM
twobitranch's Avatar
twobitranch
I have run Delo 400 15W-40 in gas engines for years and always got high mileage out of the engines working them hard.
Old Mar 23, 2007 | 04:27 PM
firstonraceday's Avatar
firstonraceday
Dual diesel/gas rated oils (Rotella, Delo, etc.) have the necessary antiwear additive packages for the flat tappet engines. The newer SM rated oils for gas engines have greatly reduced levels of zinc, phosphorous, etc.
Old Mar 23, 2007 | 08:33 PM
53fatfndr's Avatar
53fatfndr
Great stuff for engines with flat tappet cams
Old May 4, 2007 | 05:34 PM
Ranger1F150
How about in a brand new re-manufactured 351M ?
Old May 4, 2007 | 08:53 PM
firstonraceday
For sure. The reman engine needs those additives in the diesel oil for cam break in. I use it in my engine that was rebuilt last year. I'm using Rotella 10W-30. Only problem, that weight is a little hard to find in my local area.
Old May 4, 2007 | 08:56 PM
Jermafenser's Avatar
Jermafenser
If it has the flat tappet cams, your best bet is run with this additive:
http://www.gmpartsdirect.com/results...number=1052367
Old May 4, 2007 | 10:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
The additives in diesel oil reduce wear on the cam and lifters even after break in.
Old May 5, 2007 | 01:29 PM
unrulee's Avatar
unrulee
I think you guys have convinced me to switch. I can get a good deal on 15w40 form work anyway (truck shop). My only concern is starting in the winter? Does the higher viscosity make much of a difference?
Old May 5, 2007 | 01:36 PM
Jermafenser
Aren't they reducing the additives in diesel oil as well? I can't make a decision to whether run diesel oil or regular oil in my 400. Right now it's regular 10w30 oil. Pressure seems ok.
Old May 5, 2007 | 05:28 PM
firstonraceday
I was concerned as well about the new CJ-4 rated diesel oils. So concerned in fact that I sent an email to AskShell for info on the new rating (reply from Shell is in a thread in the Oil and Lube Forum entitled "FYI For Those of Us With Flat Tappet Cams"). Essentially, the Shell engineer stated that the CJ-4 rated oils still had 50% more zinc etc. than SM rated gas oils.
Old May 5, 2007 | 07:13 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can find lots of oil info on this subject in the oil and lube forum.
trusty71
Oil & Lubrication
Oct 23, 2014 09:18 AM
JaySVX
Jul 14, 2013 02:52 PM
rmcmillion2006
Dec 12, 2007 11:42 PM
bassproguy07
Jan 23, 2006 06:50 PM
oem78
Oct 11, 2005 09:33 PM
