removed lund sunvisor...
Old Mar 22, 2007 | 09:34 AM
druggles85's Avatar
druggles85
Now after I weld/glue the screw holes shut, is there any recomendations on what I could use for body filler on the top of the cab, I have had thin coats of bondo crack on similar area's due to it being on such a flexible panel. Not that looks are a major concern on my truck, I just don't want blemishes to constantly remind me of that milage stealing windcatcher. Thanks in advance!!!
Old Mar 22, 2007 | 06:52 PM
Indy_Gearhead71's Avatar
Indy_Gearhead71
Tiger Hair or any short strand fibreglass filler should work well for what you need, if you plugweld the holes in and grind them back well, you could just use Evercoat flexible filler also. Either one will work and give you a long lasting repair.
Old Mar 22, 2007 | 07:31 PM
druggles85's Avatar
druggles85
Sounds good, anything with flexible in the name sounds like what I want. i'm not all that keen on glass fillers. my problem before using bondo was it cracked directly around where the hole was plugged. I'm just glad to be rid of the visor!
Old Mar 22, 2007 | 07:33 PM
druggles85's Avatar
druggles85
Stupid me, lol, where can you buy evercoat?
Old Mar 22, 2007 | 10:32 PM
Rocket Racing's Avatar
Rocket Racing
Any auto body / paint supply store usually. Rage Gold is good.
Old Mar 23, 2007 | 07:48 AM
druggles85's Avatar
druggles85
Alright so strip entire roof, plug holes use some filler on them and other nasty rust bubbles, cut big sunroof hole, prime, and then give it all a generous coating of rubberized rocker guard.
Old Mar 23, 2007 | 05:11 PM
Indy_Gearhead71
If you don't want to use a rubberized rocker guard, you can always use a roll on bedliner, durable, with rust inhibitors built in.
Jaime74656
Dec 25, 2015 08:53 AM
j4henry
Jan 19, 2012 08:44 PM
aloonda
New Member Introductions
Sep 19, 2004 08:19 PM
krazdndenver
Sep 21, 2002 07:06 AM
leward
Jul 11, 2002 09:18 PM
