light help
Old Mar 21, 2007 | 07:34 PM
BIG-COUNTRY's Avatar
BIG-COUNTRY
Question light help
i got a 92 ranger and my dome light, hood light and cargo light dont work ive checked the bulbs and fuses and their all good . what could be wrong ?? what all else do i need to check? thanx
Old Mar 21, 2007 | 09:13 PM
fl1a's Avatar
fl1a
If it has a dash control, does it turn them on?
Old Mar 21, 2007 | 09:47 PM
BIG-COUNTRY
nope the dash control wont turn them on either
Old Mar 21, 2007 | 11:23 PM
fl1a's Avatar
fl1a
I was going to check my haynes manual for the wiring diagram, but it only has diagrams
to 1990. You might check if your local auto parts store might have a more current
edition.
Old Mar 23, 2007 | 06:17 PM
Franklin2's Avatar
Franklin2
There is 1 fuse that feeds this circuit common to all the lights you mentioned. I would double check the fuse again, and make sure one of the contacts in the fuse box has power where the fuse inserts. Also make sure the contacts are not spread open that contact the fuse.
I recommend fuse taps to people who want to add equipment to there vehicle without cutting wires, but one drawback to a fuse tap is it overspreads the contacts in the fuse box, and if you take it out, the fuse may not make contact. Someone may have had a fuse tap in that spot.
If that all looks ok, the fuse feeds a lightgreen/yellow wire which feeds all the door switches and underhood light.
armour01
2004 - 2008 F150
Oct 16, 2012 02:11 AM
islanddave
16
Jul 23, 2007 11:34 PM
clunker86
Electrical Systems/Wiring
Apr 7, 2007 12:47 PM
DjWolfman
Mar 17, 2003 10:20 PM
