I'm thinking about bypassing the IC. Why? Because I believe it contibutes to the turbo lag. It takes energy to push the air through the 7ft to 8ft of IC piping and the IC itself. That energy loads the turbine thus loading the compressor. I believe reducing the turbine load will reduce or eliminate the T lag. With my ZOODAD mod and Jobe intake, the inlet air is cooler then with the OEM air box. Using a 2.5" to 3" hose reducer (turbo outlet is 2.5") and HD flex hose, the air path would be reduced to approximately 2ft to 3ft and that could negate the efficiency of the IC. I'm going to take my OEM elbow, have it cut and the inlet reoriented toward the turbo. That would make a straight shot to the intake. Also, the rubber hose would not transfer heat like the metal pipe does.
Does anyone know of any sensors that are mounted to the IC? I have not seen any.
Any thoughts before I proceed? If it works, I may be in the 6.0L IC Bypass/Elimination Kit business.
DSMMH
Ummmmmm.... 1st, I'll pray a experimenters prayer for you. OK, now, I think the BLAZING HOT AIR is going to melt your turbo like a torch, but that's just IMO... And, oh; I know of no sensors, but I thought I saw Elvis this morning too. Good luck
Me think u CRAZY!!!!!!!! when you compress that "cooler than factory airbox" air you are imparting an another 150+ degrees to it! that is what the intercooler is there for! you will not be helping it at all. I would recomend getting in a early pre psd truck & see how you like the performance, because that is what you will get! p.s. have you ever grabbed a hold of the outlet pipe on your'e air compressor? it's the same function increase in pressure = increase in heat, please for the children don't do it! thats my $00.02!
Intercooler allows more power to be made safely.
I'm no turbo expert, but in the motorcycle race world
the nitrous guys don't want the turbo guys to have Intercoolers.
The 7.3 guy were upgrading to the bigger 6.0 intercooler.
The 6.0 guys are upgrading to Big banks coolers.
See the trend?
Cooler air makes more power!
You may build it but they won't come.
When you remove the intercooler then you will need to reduce the amount of PSI your putting into the motor. Compressing air causes the air to get hotter. So you can only compress so much now because you took the device to cool the air down to compensate for higher compression temperature.
30psi with no IC is gonna cause you way more harm than a little lag will...trust me..i wouldnt consider this without water/meth inj....have you tried the aftermarket intake elbow?? supose to help with the lag.
30psi with no IC is gonna cause you way more harm than a little lag will...trust me..i wouldn't consider this without water/meth inj....have you tried the after market intake elbow?? suppose to help with the lag.
I think he may have been looking for a business angle more than lag reduction... Can't blame a guy for brain-storming! I invented a buncha' stuff... It wasn't my fault that the world wasn't ready for the motorized revolving pet door (too many cat launches), or the fish powered lawn mower... I never did figure that one out...
Removing the intercooler WILL reduce some turbo lag, but not as much as you are thinking it would. It will raise your manifold charge temps by 200 degrees or more. While the only real detriment would be to EGT (no, it will not actually damage the turbocharger or anything else) and a rather serious reduction in air density; the marginal loss of lag will not be worth the annoyance. Intercooler removal on trucks is usually only done for competition tractor pulling; where they use full-time water injection in leui.
Direct from the guy that knows! We are all smarter now from this post.
