Won't start
Old Mar 21, 2007 | 08:08 AM
Attilak1's Avatar
Attilak1
Won't start
My 2000 7.3 won't start. I had to jump the battery yesterday, I let it run for a while and shut it off. Now I go to start it back up it turns over but doesn't start. Any help would be great as to what would be causing this.
Thanks
Attila
Old Mar 21, 2007 | 08:55 AM
Pocket's Avatar
Pocket
Well, I would start with the batteries, since you jumped them to get the truck running. You need to test them separately. The injectors won't even fire if they aren't getting enough juice, and one low battery can cause that.
If one is bad, replace BOTH.
Also check your alternator while you are at it.
Old Mar 21, 2007 | 09:22 AM
Attilak1's Avatar
Attilak1
Thank You, I'll give it a try.
Thanks
Attila
Old Mar 21, 2007 | 12:05 PM
clintbonnie's Avatar
clintbonnie
There are four things I would check....and yes, your batteries need to be good.
1. make sure your fuel pump reset switch is not tripped. (pass. side kick panel)
2. check oil level in your HPOP. about a 1/2" from the top. (remove fill screw on driver side, top)
3. remove fuel filter cap and make sure diesel fuel in the bowl. (if not, check to see if your fuel pump runs when you turn your key on)
4. check all your fuses with a ohm meter. (your can check them without removing them)
Old Mar 21, 2007 | 12:10 PM
travis dasher's Avatar
travis dasher
Test both batteries seperately and test the starter solenoid as well. I had both batteries, and the starter solenoid go out all in one shot.
Old Mar 21, 2007 | 02:28 PM
justinthompson10's Avatar
justinthompson10
This may sound dumb, where is the HPOP?
Old Mar 21, 2007 | 02:46 PM
clintbonnie
Your high pressure oil pump is the aluminum housing right under your removable black plastic cover to gain access to your fuel bowl, and front of the fuel bowl.
Old Mar 22, 2007 | 02:29 PM
justinthompson10
Thanks! I checked it yesterday and the oil level in it was A Okay!
Old Mar 22, 2007 | 03:39 PM
toadx8u's Avatar
toadx8u
im having kinda the same problem man mine wont start when its hot...but after i try and start it all i have to do is wait 30 min and it starts fine...i havent quite figured it out yet but also since yours wont start at all check that CPS every thing i have ever heard was that if its not working the truck wont run at all
