F-1 spring sliders
Old Mar 20, 2007 | 10:42 PM
gdub's Avatar
gdub
F-1 spring sliders
I'm reducing the rear spring packs on my 51 and was wondering if there were any cheap, quick alternatives to the teflon strips or buttons?
Old Mar 21, 2007 | 08:17 AM
GreatNorthWoods's Avatar
GreatNorthWoods
In the old days before teflon we used to use axle grease between the leaves or just put them back together with nothing between the leaves. The grease will help some but not nearly as much as teflon strips and it eventually dries out. I'd go with the teflon strips. Is there some reason you want another alternative?
Old Mar 21, 2007 | 11:32 AM
AXracer's Avatar
AXracer
As GNW said the old school method was to cut strips of nylon window screening and slather them with wheel bearing grease, then wrap the whole spring in rubber electrical tape to keep out dirt and keep in the grease. Then repeat the process about once a year. Use the Urethane strips unless your springs have the seats for the buttons, then use the buttons. They will last a lifetime and be cheaper in the long run.(better living thru chemistry!) Sand or wire brush the leaves smooth using lengthwise strokes only, don't use a disk grinder or such on them. Even small sanding scratches crosswise can start a crack.
Old Mar 21, 2007 | 08:04 PM
gdub's Avatar
gdub
I figured that grease was probably about the only alternative. Guess I'll order some teflon.
Thanks for the replies
Old Mar 21, 2007 | 09:11 PM
AXracer's Avatar
AXracer
Don't use teflon, use the urethane strips with the raised edges. Teflon is not good under compression pressure and will slide out from in between the leaves. Mid Fifty calls it polyride and sells it for 25.00 a roll to do two springs. Make sure what you buy is the right width for your springs.
crash1
17
Apr 21, 2012 07:25 AM
muscletruck7379
May 15, 2004 11:51 PM
johnsdiesel
All Things Towing
Jan 13, 2003 02:32 PM
winfordr
Aug 18, 2002 12:48 PM
iknowitall
All Things Towing
May 18, 2001 10:09 AM
