transmission mount confusion
Old Mar 20, 2007 | 05:50 PM
smallblock351w's Avatar
smallblock351w
Hey guys i have a 1980 ford f 150 4 x4 with a c6 automatic. I want to replace the trans mount because its dry rotted, the problem im runing into is every mount i order for it is different. The mount that is on this truck looks like 2 hockey pucks sitting on the crossmember, with a steel plate bolted on top of them, then 2 bolts go through the steel plate into the trans, now i know ive seen this on a couple other ford 4 x 4 trucks, so any idea what the confusion is or where i can get a mount?
Old Mar 21, 2007 | 09:54 AM
hoxiii's Avatar
hoxiii
I had some issues trying to get the proper mount for my truck so I bought a set of radius arm bushings for the same year truck. The thinner half went right between the crossmember and mount, hung the bigger chunk under the crossmember, and then ran a pair of grade 8 bolts through them. Worked like a charm.
Justin
Old Mar 21, 2007 | 10:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The reason you keep getting the wrong parts, is because you are ordering the wrong parts. You actually want transfer case mounts, not a rear motor mount. Most parts books (exc Fords) don't show the difference. Ford parts books list a rear trans mount for 2WD only. 4WD is different.
Please list engine size when asking questions!
See next post for correct part numbers.
Old Mar 21, 2007 | 10:29 AM
NumberDummy
1980/89 F100/350 & Bronco .. 4WD rear engine mounts (transfer case) 302 / 351W / 351M-400
2-E1TZ-6E039-A .. Rear Insulator-UPPER
2-E1TZ-6E039-B .. Rear Insulator-LOWER
Old Mar 21, 2007 | 02:41 PM
smallblock351w
351winsdor
Old Sep 2, 2007 | 04:03 PM
1980FORD's Avatar
1980FORD
I just found this thread and it may save my butt. I have the same problem with a 300 l6 and a T-18 4X4. I understand what I am looking for but are they a dealer only part or can I get them at an autozone (or any other parts store)?
Old Sep 3, 2007 | 09:37 AM
smallblock351w
i wasnt able to get them despite what the above poster had said, they dont list them. Best way i found around it was, i welded up the holes in the crossmember and switched to the newer style mount.
Old Sep 3, 2007 | 09:58 AM
1980FORD's Avatar
1980FORD
Thank you for the info. I may try that.
bives
Apr 29, 2017 04:22 PM
Okobojo
Feb 23, 2017 07:54 PM
Dirtbag
Dec 20, 2016 08:55 AM
lowtrkn2k
Sep 7, 2012 02:17 PM
hydra1998
All Things Towing
Jul 16, 2006 09:48 PM
