5.0 swap
Old Mar 20, 2007 | 05:03 PM
cruzin55f100's Avatar
cruzin55f100
Question 5.0 swap
my truck is an automatic, if i install a 5.0 with a c-4 transmission can i still use the original column shifter.
Old Mar 20, 2007 | 06:53 PM
black58's Avatar
black58
Yes, you will need to modify the linkage though. It's pretty straightforward.
Old Mar 20, 2007 | 08:43 PM
cruzin55f100
do i have to change out the drive shaft?
Old Mar 20, 2007 | 10:15 PM
felixr's Avatar
felixr
I am also doing the exact same swap and am interested as well. chiming in to get added to the response to thread email thingy and to perhaps add any pointers as i go through this swap that i may come across. . . hopefully you can do the same cruzin.
good luck to ya! i'll be in the same boat
Old Mar 20, 2007 | 11:16 PM
Fomoko1's Avatar
Fomoko1
If you have a stock drive shaft then it will need to be changed for this swap.
Not a big deal, a machine shop can fix you up fairly quickly.
Old Mar 21, 2007 | 06:33 PM
cruzin55f100
so the drive shaft would have to be cut and rewelded? and how do i determine how much to cut.
Old Mar 21, 2007 | 06:46 PM
Fomoko1's Avatar
Fomoko1
Once the engine/trans is in the correct place carefully measure the distance from the end of the transmisson output shaft to the pinion yoke.
A quaified machine shop will be able to do the rest according to these measurements. Not a problem for them, this is a common every day procedure for them.
Old Mar 21, 2007 | 09:27 PM
jimhackney's Avatar
jimhackney
Driveshaft measuring
Go to this website, http://www.dennysdriveshaft.com/html...o_measure.html
They have a pretty good explanation as to how to measure.
Old Mar 21, 2007 | 09:46 PM
felixr's Avatar
felixr
anyone know if there are any stock or custom PRE-made driveshafts that would fit?
Old Mar 21, 2007 | 10:02 PM
jimhackney's Avatar
jimhackney
will stock fit
Gotta measure to find out.
Old Mar 22, 2007 | 11:58 PM
bememe's Avatar
bememe
If you take the measurements you can always try locating a junkyard shaft that matches. You may have to swap around tranny yokes though.
Old Mar 23, 2007 | 07:55 PM
felixr's Avatar
felixr
does the c4 have overdrive? is the c4 the best choice for a 302 on our trucks?
Old Mar 23, 2007 | 09:16 PM
Max E's Avatar
Max E
C4 does not have OD . I am using a AOD. It is a four speed overdrive. Very common in Mustangs and Marks and and and.
Max E
Old Mar 24, 2007 | 12:57 PM
cruzin55f100
the 302 that i have came out of a 85 mustang, what is the difference between a c-4 and a c-6? also will i have trouble running the exhaust?
Old Mar 24, 2007 | 06:50 PM
Max E's Avatar
Max E
I believe they are both 4 speed auto but one is heavier duty. The six of course. You want a AOD It is a four speed with over drive. My is out of a Mark.
I know they had some trouble with the c4 in the ford vans, but I haven't heard of any trouble with the c6. I am a cruiser and not a rodder so I want the od. (Not that I wouldn't spin the tires a little now and again)
Max E
