5.0 swap
The C4 trannys are fine, and if you run higher gears, 3.08-2.75ish, you can cruise (55-60) at a reasonable engine speed (2000-2500ish). A C6 behind a 302 will rob you of about 40-65 hp, so all that money spent hopping up that 5.0, will be wasted before it gets to the driveshaft, sorry. Also, if you run the higher gears, I would recommend an auxillary trans cooler to help with the heat build up at slower speeds.
My '93 Cougar AOD has two connectors, one for the VSS, IIRC, as well.
It's not an electronic OD tranny from what I have read.
There was 3 versions:
AOD 1980-92
AOD-E - 93-95
47RW 93+ (Used on the modular engines)
No, you dont HAVE to connect the switch, but it will start in ANY gear, dangerous to drive, not good on tranny/starter, and also will not have backup lights; may need them to let others know you want to back out of a parking space, help to see where you are backing at night. Some also have another set of contacts: hot in run, closed in R, OD, D, Lo for throttle kicker on carb.
I say Lo, B/C I have seen the AOD with neumerous valvebodies,
PRNOD21-cannot remember year, but was F350 4bbl 5.8
PRNOD1-85 E150 (in 1, downshifts go to 2, then 1 when safe, when starting out, it wont shift past 1)
PRNOD2-89 CV (D and OD used 1 and 2, 2 used only 2), and
PRND21 with OD button, late (8/)92 E250, could be 93 electronics.
89 Crown Vic had cruise, but had VSS adapter under hood; 85 E150, not sure, no VSS on vehicle, 4th owner
; 92 E250, VSS on speedo cable head, had cable AND VSS; F350 was on T-case
The C6 is a big heavy cast iron unit that's dang near bullet proof. Lots of racers use them so there are plenty of parts and a good aftermarket for them. However, they're made for big blocks and FE's not small blocks (351w on down).
I do have a question though, that I thought I'd put to the experts here...
(warning
)Anybody know know the gear reduction on a stock c6 in third gear? (Reason I'm asking is I've got a 410 I'm rebuilding and a C6 to mate it to (1966 version), with 3.25 rear, and I'd like to get a guess at how many rpm's I'll be running at if I'm cruising at 70mph. I know that if I can get the reduction ration of the top gear in the C6 I can calculate out the approximate rpms) Thanks to anybody who can point me in the right direction!
