I did a search but didn't turn up anything (searching "390 measurements" didn't turn out pretty lol). I'm looking for the measurements of a 390, length (preferably including accessories and fan), width, and height (including air cleaner).
From memory the only thing i can be 100% on is the length. From mounting flange to the end of the fan (Ford factory flex fan on a C5TE Ford fan spacer) comes out to 34".
I don't recall if i measured the width from the outside edge of the head to the outside edge of the head, or if i just measured across the bare block, but the number i remember is 23"
EDIT: based on bore size and deck height, the 390 block should be about 20" across, so the 23" above would be from the outside edge of the heads, not including valve covers or exhaust.
