First Weekend Update
First the good news. I had an exhaust system put in on Friday with an Dyno-Max muffler. The guy was honest and said it wouldn't make much of an "old skool sound", as I may have wanted but the extra horse power was worth the $30. Total $220 including labor.
Even better news. I just picked up my first mechanics tool set yesterday too. http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
I know it's not MAC but it's always done my dad well and in fact he gave me his old drum tools because that's going to be an upcoming project. So with that tool set I did my first full tune up. Oil, Filter, and Plugs. The wires and cap we're fine so no changes there.
Now to the bad news. So with the muffler on I now noticed quit a bit of smoke coming out of the exhaust. So my dad looked at her and said I'm probally burning oil. And he says I'll need some new rings. But I don't think that is bad news for me because that means, this girl, is going to learn how to replace a rear end and dive into some heads. I can't wait!!!
When I have the money, of course.
Or should I be worried that my husband is driving that car 22 miles round trip each day?
If its not smoking too bad then you might be able to put of an engine overhaul for awhile. Before you got the truck had it been sitting for a long time? While you are driving the truck have someone follow you and note when the truck is smoking. Does it smoke at idle? during acceleration? while you are coasting? etc. This can give you some idea of what it the cause is, rings, vavle guides, etc
I actually made a bit of progress also. I got my battery re-located so that it will be recessed below the new bed floor I'm installing. I started the painfully slow process of making careful measurements and worrying and hand wringing that must be done before any cuts can be made on my donor bed floor (2005 GMC)
Bobby
All that to say just keep an eye oil the oil level.
Heck, the poor ol' girl has a few years on her and deserves to puff a bit now and again
Bobby
Does that sound ok for now?
My theory....... as the engine sits oil runs down the valve stem past the valve seal and into the combustion chamber...then when engine is started oil burns off causing blue exhaust smoke on startup. On revving the engine......vaccuum increases and oil is drawn past the seals into the combustion chamber .....again causing blue exhaust smoke.
The seals are probably dried out from sitting....... I would put it on the to do list..... but not a big concern yet :-)
You should probably do a compression check to verify the integrity of the rings and valves........ but totally up to you.
Thanx everybody. I'll follow up with some more questions later this week with my next weekend project.
(Hint Gages and Prep Work for Paint)
I just put in 10w30 but I will upgrade that oil per all you'all recommindations.
There is a trick that my father-in-law and uncle told me about that might help with inner engine build up. The trick is to run the engine, in neutral and rev the motor at a steady higher rpm and pour water into the carb. Not too fast to stall the motor. The water will go into the engine and basically steam clean it from the inside out. My father-in-law told me he used to have a guy that call up and say the car was running poorly and he would go with a couple of gallons, you read that right, gallons and pour it in while reving the motor up and it would clear it up. Both my uncle and father-in-law were mechanics for 30 years or better. I don't know if anyone else here on the bard has tried this. I have and it works.
Basically run the engine in nuetral at about 2500-3000 rpm and dribble some water down the carb (don't pour in so much as to kill the engine) Years ago you could actually buy an add on water injection system.
Back in my days working as a mechanic (when there were still tons of old ladies driving the huge carburated land yachts) we would have several come in with their cars barely running. You'd pull a spark plug and they'd be brand new but covered with brwonishblack carbon deposits. We'd take the cars out, put the automatic trans in 1st gear and stand on the gas. We'd leave it like that, the trans would eventually shift (early TH350's and TH400's). There would be huge clouds of brownish smoke. After a few runs like that the cars would run great. Basically these old gals never drove their cars long enough to fully warm up the engines and if they did they never drove the cars hard at all.
You got to step on them once in awhile.
Bobby
When I start her I pull the choke all the way out to get her started. Then after a quick "almost" start I push the choke in but not all the way. After about a 10min drive it idles really high.
So my question is should my choke be pushed all the way in when it's warmed up? And what is making my carb run so rich when it's all warmed up? Anything I can do without taking it in?
The little inline 6 that is in my wife's Falcon is a manual choke. I start it much like you do. I pump it once or twice, pull the choke all the way out and it starts right up. After about a minute I start pushing the choke **** in, basically giving it less and less choke as it warms up. The amount of time depends on the outside temp.
With the engine warm you should have the choke **** pulled out at all. that could be causing your rich running condition.
Bobby
