Oil filter drain chute
Old Mar 19, 2007 | 10:39 AM
mattd17's Avatar
mattd17
hi all, i was just wondering if anyone else has the issue that i have with my oil filter drain chute? well, all i can say about it, its practically worthless !!! its a good idea to have it there, but mine always flows over the back side, and makes a mess regardless !!! anyone else experience this and have a remedy? thanks !!
Old Mar 19, 2007 | 10:58 AM
gui88ford's Avatar
gui88ford
park the truck slightly downhill and you will have no problems....
Old Mar 19, 2007 | 11:35 AM
mattd17's Avatar
mattd17
i never thought of that... maybe since i always do the changes inside my garage. maybe i could just put my floor jack under the pumpkin and simulate the decline. thanks for the advice !
Old Mar 19, 2007 | 11:52 AM
gui88ford's Avatar
gui88ford
yeah, i never had that problem but i would think that would work fairly well...or even a set of ramps then just back the truck up on the ramps....that would do it for sure......just be careful that it's not to much of an incline so all the oil comes out of the pan...
Old Mar 19, 2007 | 02:50 PM
mik369's Avatar
mik369
Same here guys, I liked the setup on my 97 where the filter was in front of driver side wheel. No matter how I park it seems to be messy but my wife has mustang and she's on the mustang forums alot as while I a'm here. Someone said they use a gallon size freezer bag and put around the filter while taking it off I did this and it does work good ,if your careful and don't let the bag bunch up..Just a thought.
Old Mar 19, 2007 | 09:35 PM
F150Texan's Avatar
F150Texan
I just barely spin mine off until it trickles, when it quits trickling, I unscrew it all the way off. Never any messy problems here.
Old Mar 19, 2007 | 11:11 PM
mattd17's Avatar
mattd17
thanks mik369..... i really like the idea of a freezer bag.... much easier than waiting for the filter to slowly drain out..... i dont run a shop, but i still like to be done in 15 minutes !!!
Old Mar 20, 2007 | 09:06 AM
powderburn2's Avatar
powderburn2
Don't jack it up on the pumpkin. It could cause oil leaks on the axle shaft housings, At least thats what it says in the owners manual.
Old Mar 20, 2007 | 12:36 PM
Doogie S's Avatar
Doogie S
powderburn2,
You beat me to the comment...
Jacking up on the pumpkin can cause the cover to distort and leak. There is a special fixture Ford makes specifically for this.
The approved method is to jack up each axel independently.
I get a little dripping over the back side of the oil drain chute, but nothing severe or worth noting. I just move he pan back a little to catch anything that runs over, which seems to work for me. Perhaps a larger catch pan might help.
Doug
Old Mar 20, 2007 | 02:17 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Easier yet is to use a hunk of aluminum foil from the kitchen....mold it to form a funnel from filter to oil pan...works great on my '97 Mark VIII and that filter is a nightmare to change.
Old Mar 20, 2007 | 03:11 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
good ideas. I'll have to try the plastic bag one. I haven't noticed any issues with spillage yet, but better to be prepared than caught unawares
