Power Upgrades?
Old Mar 18, 2007 | 10:59 PM
snipAR-15's Avatar
snipAR-15
Power Upgrades?
I just recieved a 1996 ford F150 from a family member with a 4.9L engine. It has 160000 miles. Everything is in good order, engine was properly maintained.
So, what are some good cheap ways to get more power?
Old Mar 18, 2007 | 11:37 PM
bobscoot000's Avatar
bobscoot000
most common are new exhaust and some sort of intake, whether home made or something like a k&n. Also when you say power, are you meaning power as horsepower, or "power" as in pulling a trailer or mudding? Maybe gearing if your looking for power to pull a trailer..
Old Mar 19, 2007 | 09:47 AM
Motorhead351's Avatar
Motorhead351
If by cheap you mean under $100, there is only one I can think of off the top of my head. That would be to convert your rockers to adjustable and throw on some GM 1.7 rockers. You could modify your exhaust for that amount. In either case, it not gonna make your truck appreciably more enjoyable to drive.
Think long term. Start saving, reading old posts, get a handle on whats needed to make some real power. Then when you have enough money saved, you'll be able to build a nice I-6 or go ahead and do a v8 swap.
Old Mar 19, 2007 | 09:58 AM
bobscoot000
what amount are you talking about?
Old Mar 19, 2007 | 02:24 PM
Silver Streak's Avatar
Silver Streak
$100 won't do anything of any significance other than the exhaust. Don't waste your money on a K&N or any other intake system. The rocker conversion will not even be close to $100, and makes very little difference at all. I got 2 hp at peak and maybe 5-6 hp a few hundred rpm beyond peak.
Do a good tune up with quality parts, set the timing ahead 2-4 degrees, and put a 2.5" exhaust with a quality muffler on it and see what it does for you. Beyond that your checkbook will begin feeling unconfortable.
Old Mar 19, 2007 | 07:54 PM
Motorhead351
Sure it can.
The crane screw in to stud kit, along with stock GM 250 rockers, comes out to right around that amount. I didnt say roller rockers.
In any case. Just an observation not much of a point, as its a worthless upgrade.
Old Mar 19, 2007 | 10:38 PM
bobscoot000
Talking
Exhaust will make it more enjoyable to listen to.
Old Mar 20, 2007 | 07:40 AM
Motorhead351
Oh boy...thats a whole other bag of worms.
Old Mar 20, 2007 | 02:15 PM
Silver Streak
The cheapest Crane conversion that Summit sells is $85. It is for a V8, so if you could get one for a 4.9 you might get it down to $70, but I doubt it. The stock rockers for the 250 cost about $4 each, so that's another $50. A set of poly locks is about $30. Don't forget that you'll need a valve cover gasket and maybe a plenum gasket, that's another $30 or so. Sounds like well over $100 to me. You could probably take a few shortcuts and knock a little off, but you can't do it right for $100.
Old Mar 20, 2007 | 05:07 PM
Motorhead351
If you sleep better tonight, It cant be done for exactly $100 or less. Your right!
With that said, Im guessing the vasoline is free at your parts store.
Old Mar 20, 2007 | 06:09 PM
300I6VAN85's Avatar
300I6VAN85
If I were in your shoes I would live with what you have untill you know more about the I6 300 and what you want out of it. More power for what? It's not a sports car, it's a dang good truck. Look at what you "recieved" from family member, who knows the history of this truck. Every thing in good order. Engine was properly maintained. 160,000 miles.
I don't think you have a clue how well off you have it. My honest free opinon is get use to it the way it is now. KISS. Keep it stock stupid. You might ask the doner about modify their old truck if you are in thier last will.
Old Mar 21, 2007 | 08:06 AM
Silver Streak
Motorhead, I would love to hear where you can get that stuff all for $100 since you obviously have a better source than I do.
Old Mar 21, 2007 | 09:00 AM
bchunter's Avatar
bchunter
Originally Posted by 300I6VAN85
If I were in your shoes ..............
This is very true as I was in the same boat. My dad wanted to get rid of his 96 for a new F-150 so I grabbed it off him for a steal. I have loved the truck since he got it. The only thing that I have done to it is the lift and gears. My dad opened the cats before and it kept thowing codes so I replaced the cat with a good aftermarket cat and threw on a piece of 3" pipe that I had kicking around with a Flowmaster 50 on it.
I have toyed with camming it, but it runs so good now (135,000 kms) that I have a hard time spending the $ on that. I will do it in a bit for sure once I redo the timing gears.
The way I look at it is that Ford took this truck off the road after our year, so they realised that they could not beat their own best Enjoy the truck.
Old Mar 23, 2007 | 09:44 PM
montster's Avatar
montster
switched my rockers to chevy for $32 us but mine is a 1980 motor and it made a noticable difference at low end torque off road and it is now almost imposible to stall out, cant say its a big difference on the street though, I ordered rocker arm kit for a 76 chevy 250 and got new lock nuts (the one in the kit were wrong size) so guy at the store swaped them for me
Old Mar 24, 2007 | 01:22 AM
snipAR-15's Avatar
snipAR-15
SO, where can I get on exhaust system? ( preferably one that exits before the rear tire)
