87 5.0 still missing
Old Mar 18, 2007 | 10:14 PM
87black150's Avatar
87black150
1987 F150 with 302 has been missing pretty bad when I hit a hill with it. I have changed plugs, wires, distributor cap, rotor button and fuel pressure regulator. Also changed the TFI module recently. The miss is still there. I checked the fuel pressure today. With engine off and fuel pump grounded to run, I have 40 psi. With the engine running, the pressure is 32 psi. My manual says 30 to 45 psi while running. 32 seems a little low to me. When I pinch off the return line, the pressure shoots up drastically. Any ideas?
Old Mar 18, 2007 | 11:46 PM
eco's Avatar
eco
Why do you think the engine has a missfire when under load?
The fact that the pressure shoots up when you pinch off the return line is a good thing...it's suppoesed to do that. How does the engine react to that added psi?
Old Mar 19, 2007 | 12:00 AM
ryan f150 4x4's Avatar
ryan f150 4x4
cheack your egr switch . thay will make it miss and pritty cheap
Old Mar 19, 2007 | 04:53 AM
87black150's Avatar
87black150
It's pretty obvious it's got a misfire when you're driving it and hit a hill. You can feel the jerking as soon as it starts pulling hard.
Yeah, I know the pressure is suppose to do that. I wrote that so everyone would know that the fuel pump seems to be working OK. The engine will rev up slightly when the fuel line is pinched shut.
failsatheals
1997 - 2003 F150
Jun 21, 2016 09:03 PM
Demonhawk
Oct 8, 2015 05:00 PM
cjben
Aug 30, 2015 11:24 PM
1992FordF150Custom
19
May 25, 2014 01:03 PM
cougardude70
Oct 10, 2003 11:40 PM
