Electic Choke?
Old Mar 18, 2007 | 09:15 PM
brentleedragon's Avatar
brentleedragon
Electic Choke?
Hey guys with my previous thread basically helping me figure out that my choke is dead. What are the benefits of switching to an electric choke? What have you found to be problems when installing them? are they a pain in the rear-end? and what is the best one for the best price? ughm thats all I can thinkg of right now about the chokes any help you can give is amazing
im running in my 79 f150 a 302 2bbl carb c6 thanks
Old Mar 18, 2007 | 09:33 PM
ford4life69's Avatar
ford4life69
i've got a 79 f100 302 2bbl c6 setup... mine has the stupid electric choke assist thing going on and has been broken for a few years now. got a new one put on and the dumb thing still doesn't run right after getting everything adjusted and bla bla ... *shrug* I know that's no help but in case someone else does have some help, now there's two of us listening
dot dot dot
Mil1ion's Avatar
Mil1ion
Cheap... easy swap .
You basically install a electric choke where a Non-electric is and wire it to the stator terminal of the alternator. Done !
Old Mar 18, 2007 | 09:38 PM
brentleedragon
i knew dennis would make that sound easy....do you know of a good know one though?
Old Mar 18, 2007 | 09:41 PM
ford4life69
now I know where to find a wire to use since dad said the one they had on the one that was there when we bought it was a ground wire.....
*shaking my head*
Old Mar 18, 2007 | 09:45 PM
Mil1ion's Avatar
Mil1ion
I think they all come from the same pot.
http://info.rockauto.com/Airtex/Detail.html?2C1210.jpg
You can use one off any Car as well.
Just check for if it's working or not with a power supply.
Old Mar 18, 2007 | 09:47 PM
brentleedragon
that pic you sent, I messed with it on my truck, and when I did the first time it didnt do ne thing, the second time it now doesnt kick into auto choke, not bad really but my mechanic friend said to replace it....or should i just keep messing with that till it works or something?
Old Mar 18, 2007 | 09:52 PM
Mil1ion's Avatar
Mil1ion
Note:
The little arm in the choke housing is supposed to slide into the end part of the choke spring.
Then the black choke housing has to be indexed to the proper notch.
The choke linkage/fast idle linkage to the carb has to be properly adjusted for the choke system to work properly.
That's why I linked the autozone page.
Old Mar 18, 2007 | 09:54 PM
brentleedragon
well my friend down at napa who was a mechanic for ford for like 30 years said that it sounds like the spring for the auto choke isnt warming up....yet not the auto choke isnt even comming on
Old Mar 18, 2007 | 10:00 PM
Mil1ion's Avatar
Mil1ion
Yes...That's what happens to them .
Heat and just being used... fatigue
