Fuel Filter Light
Old Mar 18, 2007 | 06:08 PM
Gregg C.'s Avatar
Gregg C.
Fuel Filter Light
I own a '95 F-350 PSD with about 190,000 mi. Driving down the road today the fuel filter light came on. In about a mile it started to skip so I pulled into a lot and then the truck died. I opened up the fuel bowl which was full. I then realized I just changed the filter about 2000 mi. ago so I put it back together and switched to the other tank. Truck fired right up and has run good since. Is there a seperate fuel pump in each tank? We just went through a real good snow storm here where the truck ran for about 26 hrs. straight. No Problems. Any ideas what it could be.
Thanks
Old Mar 18, 2007 | 06:45 PM
tjbeggs's Avatar
tjbeggs
only one fuel pump and it in the valleyu of the engine. you have a line from the tank to the selctor velve that is plugged I would ahve to imagine. The selector valve is on the insdie of the frame right at the front tank.
