Mixing Oil Weights?
Old Mar 18, 2007 | 11:01 AM
fpd7's Avatar
fpd7
Mixing Oil Weights?
I have one quart of Rotella 10W-30 left over from winter. I'm getting ready for summer and was getting Rotella 15W-40. Can I put in one quart of 10W-30 along with 14 quarts of 15W-40? I'm not really even sure what those numbers mean other than the thickness of the oil. Thanks. Joe.
Old Mar 18, 2007 | 11:07 AM
Bushwhacker's Avatar
Bushwhacker
You could if you wanted but why not just save the 10w-30 for next winter. You'll need it then.
Old Mar 18, 2007 | 03:26 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
It's never a good idea to mix oil weights. I'd hold onto the lighter weight oil and use it next Winter.
Old Mar 18, 2007 | 03:44 PM
Tedster9's Avatar
Tedster9
I wouldn't say it's "never" a good idea, in a pinch wouldn't think twice. Bob Pirsig in his Drive It Forever book (Bob was an SAE guy) said that mixing weights is OK provided the resulting (averaged) weight is acceptable for the temperatures being operated at. A quart of 5w-30 with four quarts of 10w-30 is just going to result in a viscosity somewhere in between the two. What is not necessarily OK, mixing different brands of oils (even if of the same weight viscosity) that are derived from different major base stocks, like say a Pennzoil and Castrol, something like that. Paraffin based oils are actually very good but tend to gum up badly if regular maintenance is not performed, short trips, etc.
Old Mar 18, 2007 | 04:13 PM
mrxlh's Avatar
mrxlh
Pretty solid advice.
CB3
15
Nov 25, 2016 08:16 PM
anthonym92
21
Sep 12, 2015 03:42 PM
jmuenchow
17
Dec 16, 2014 11:24 PM
big poppa
23
Nov 17, 2010 10:30 AM
mrxlh
May 28, 2004 06:35 PM
