2 helper springs?
Old Mar 18, 2007 | 10:51 AM
84f250460's Avatar
84f250460
2 helper springs?
i was wondering if it would be possible to put 2 helper springs on each side in the rear. while my rear is out already i plan on adding a few springs so instead of the 3 that were on it im ending with 5 and possibly 2 helpers? any thoughts on this?
Old Mar 18, 2007 | 04:38 PM
Sycostang67's Avatar
Sycostang67
My first truck (83 F-100) had add-a-leafs, air shocks, and those coil springs you bolt to the axle. #2500 of wood pellets would still make the rear drag. What do you need so many helpers for, it may worsen your ride.
Old Mar 18, 2007 | 07:43 PM
77monster's Avatar
77monster
can you say "ride like a log wagon"
Old Mar 18, 2007 | 08:35 PM
84f250460's Avatar
84f250460
well after hearing that mayb it isnt a good idea thx for saving me sum down time guys
Old Mar 18, 2007 | 08:59 PM
77monster's Avatar
77monster
if your wanting more load carrying then go with inflatable air bag helper its simerlar to airshocks and the coil spring bolted to the axel combined they mount to the axel and you inflate them till your truck is leveled like airride on a 18wheeler .when not in use you can deflate them get an onboard compressor and make it even easyier to use
Old Mar 19, 2007 | 08:57 PM
power_speed's Avatar
power_speed
Mr Monster has a good idea. I am thinking about taking some of the leafs out of my truck to smooth out the ride. Then putting some air bags to help out when need be.
Old Mar 19, 2007 | 09:56 PM
Pkupman82's Avatar
Pkupman82
Go with the air bag system, it's the only way to fly nowadays!
Old Mar 20, 2007 | 03:30 AM
77monster's Avatar
77monster
i have the airbags on my 250 and there nice i get a smooth ride (as smooth as a f250 gets) then when i need extra capacity i just inflate the bags
Old Mar 20, 2007 | 11:17 AM
hoxiii's Avatar
hoxiii
I'm a fan on the over the pack helper springs. My truck came with them factory and the next time i have my axle out (shortly for spring bushings and u-bolts) I'm putting an additional spring over the pack. Added spring capacity without affecting the ride one bit.
Justin
Peavey1986
Apr 21, 2015 12:36 AM
low 66
Oct 23, 2010 10:31 PM
crestfallinman
Oct 17, 2008 11:37 PM
slim pickens
May 14, 2008 05:45 PM
thinck
Jul 3, 2003 03:05 PM
