helper spring
Old Oct 23, 2010 | 06:51 PM
low 66's Avatar
low 66
helper spring
Ok I'm lowering my 66 and on the rear their is a load helper do I have to remove it or can I just cut off the ends so that they clear the bracket on the frame
Old Oct 23, 2010 | 08:48 PM
cj06's Avatar
cj06
is it bolted in with the spring pack or is it a add on ? if part of the pack you can cut the end off or remove it , if it is a add on throw it away !
Old Oct 23, 2010 | 09:02 PM
low 66's Avatar
low 66
I believe that it is a factory installed helper in 66 so u r saying I can cut it off or is it better to remove it
Old Oct 23, 2010 | 10:04 PM
cj06's Avatar
cj06
better to remove it , you will need new center bolts for the spring pack . NAPA will have them
Old Oct 23, 2010 | 10:31 PM
low 66's Avatar
low 66
Ok thanks Napa I head
Shadowrider123
Oct 13, 2013 06:58 PM
driller tom
2004 - 2008 F150
Sep 6, 2011 06:53 PM
mikedeason
Nov 7, 2006 12:58 AM
Beefford
2004 - 2008 F150
Apr 25, 2006 09:17 PM
GeneStoner
Mar 27, 2003 03:37 PM
