how to lower the rear end?
Old 03-17-2007, 02:27 PM
Jeff-150's Avatar
Jeff-150
Jeff-150 is offline
i put some new tires on my 95 f-150 yesterday and they look great (275/60/r15). but, i dont like how much fender well shows in the back. the front is fine. i don't want my truck to be too low, just leveled. i cant seem to find lowering rear leaf springs.
Old 03-17-2007, 02:55 PM
lostin90s's Avatar
lostin90s
lostin90s is offline
I take it you have a 2x4 . How much you need to go? You can get 2" lowering shackles . Remove a leaf spring or 2. Put custom block under spring that is thinner. Or run around with weight in back of bed. HaHa
Keep us posted.
Old 03-17-2007, 06:46 PM
TommiFIN's Avatar
TommiFIN
TommiFIN is offline
Who makes/sells 2" lowering shackles? I also would like to lower my ´89 F150 a little.
Old 03-17-2007, 07:01 PM
lostin90s's Avatar
lostin90s
I don't know but have seen them on eBay last week and in sports truck magazine while back. I'd check with any of the sport truck suspension company.(lowering kits )
Old 03-17-2007, 07:42 PM
bigredneck47240's Avatar
bigredneck47240
bigredneck47240 is offline
i have a question that deals with this i have a 4.2l 4x2 lon wheel base truck and would like to raise the front to level the truck out im a redneck and usually im found off road somewhere so i dont want to lower it. is there any cheap ways i can do this. maybe my next truck will be a 4x4 and i dcan jack it up but im stuck with this one till i get it paid
Old 03-18-2007, 05:36 AM
TommiFIN's Avatar
TommiFIN
TommiFIN is offline
lostin90s: I´ll try find them from ebay,thanks.
bigredneck47240: BroncoGraveyard sells 2" poly lift spacers,they cost 95 dollars. There´s also new stiffer/longer front coil springs for sale.
Old 03-18-2007, 09:03 AM
bigredneck47240
thanks man i appreciate it
Old 03-18-2007, 10:14 AM
92F150Flare's Avatar
92F150Flare
92F150Flare is offline
LMC truck, Summit racing, Jegs, JC Whitney.. all on-line catalogs....I've seen kits at AutoZone too........the 2 inch shackle drop is really common.
If you're broke.....take a torch to the front 6 inches of the spring and let the truck settle......cheap and fast.
Good Luck
Old 03-18-2007, 04:56 PM
F250Tech's Avatar
F250Tech
F250Tech is offline
coil spring jacks or change coil springs to 3/4 or 1 ton springs and adjustable ball joint sleeves
Old 03-19-2007, 02:40 AM
TommiFIN's Avatar
TommiFIN
TommiFIN is offline
Good Luck
I´ve searched them from summit before but I couldn´t find them but now I did.
Thanks for a tip.
Old 03-19-2007, 07:01 AM
wrenchturner's Avatar
wrenchturner
wrenchturner is offline
i would just google a drop shackle. heating springs isn't always a real good idea.
http://www.rpmoutlet.com/lightmagna.htm
http://www.stylinconcepts.com/part.a.../categoryid/30
chrome85
2015 - 2020 F150
05-26-2015 10:56 AM
JHalvorsen
04-27-2015 09:16 PM
5.0STX
2009 - 2014 F150
33
12-18-2014 12:13 PM
f100T
11-18-2014 06:33 PM
Ron
07-15-2001 07:43 PM
Quick Reply: how to lower the rear end?
