How low is she?
How low is she?
My '76 F100 was lowered when I got it it, however I want to go lower. The big problem I am having is I don't know how much the PO lowered it so I don't have a base line for a new lowering kit. Is there a base measurement I can us to determine the amount of drop I have now?
A base measurement? Sure....
Have someone with a similar vehicle provide the vertical measurement from the wheel hub centerline to fender arch because that takes out any difference caused by tire size.
Btw, the typical measurement from the I-beam to a stock bumpstop is from 2.25 to 2.75 inches.
All that is needed to get ya in the ball part is a 73-79 2WD F100/F150 that hasn't been lowered.
Larry, we need to determine how much the suspension was altered to lower the truck... tire sizing only confuses the matter and should be removed from the equation.
Is that from the center of the hub to the wheel arch?
Ya got stock I-beams, right? Measure the distance btwn the I-beam and bumpstop.. it should be around 2.5 inches.
sandymane
03-11-2018 02:58 PM
girlwithatruck
06-16-2011 10:22 PM
hydrofanatic
08-26-2007 04:57 PM
rallyman
08-23-2002 07:49 PM
